Look at this : another vintage find
Kenmore by Sanyo
Yes, dartman, this cute lil' japanese babe still works fine. : ) I had to tip the machine to check for some leak somewhere under the tubs. A few drops on the floor, suspect one of the connector (joints) of the pipes. Armed with silicone rubber gel I tried to figure out where the source of the leak might be. Think I just found it
Thank you Christina (hippiedoll).
So fun to use... This is my favorite in term of agitation (how 'violent' and effective is the powerful whirl produced by that impeller!!) This vintage machine looks a lot like the Hitachi twin tub my grand ma used in the early 1970s (though somewhat different in design). Since 2012, this latest addition is my eleventh twin tub washer (I still have 9, including my american beauty --Hoov 0510-- to which you added some value thanks to the original drain hose you sent as a gift!)
vacbear, the Sears catalog is 'Fall 1971' which fits with the dates mentioned on a sticker at the back of the washing machine: 'Guarantee Sears' ... 'A maintenance agreement extends coverage' ... 'Jan-Dec / 1970-1972' ('Oct' and '1972' have punch holes)
Thanks, Matthew
Thought it was a sort of filter or something but, indeed, the overflow gizmo seems more logical here as it is located towards the top of the tub. When in action some X quantity of liquid is 'evacuated' through this drain, due to the forceful storm active inside the wash tub (...that impeller again!)
Sanyo
Going back through the archives... Ref.: thread 41662 - back in 2012!
This little Sanyo twin tub looks almost exactly like the (branded) Kenmore
(seems like the power cable, for some reason, was suspended over the control panel on that picture)
Sanyo again
Same aluminum tub, impeller, drains, stylish silvery control knobs, and spinner... (different control panel though)
Kenmore 21300 (Sanyo)
Did I promise more pictures, gansky ?
Here they are :
Wash timer (this photo comes from another machine -- same exactly as mine)
Control panel removed (and, also, all top trims revoved)
(the silicone gel is one of my little 'fixes', 'additions', 'improvements', etc.)
Without the large, all-plastic, control panel (except for the greenish aluminum section where are located the three control knobs)
all plastic strips (top trim) removed
Looks great! Can't wait to see it in action. Have fun with it.
On an unrelated thread a member commented he was never interested in baking until he had access to a wall oven mounted high enough for him to use without bending & stooping. Not long after reading that I was led through a lesson on twin tub use by 2 very patient teachers (Yogi & NewVista58) when it clicked: My lack of interest in ovens and twin tubs was ONLY because they were too low to the ground and therefore painful to use (arthritis on top of bad hips & back). Now I totally see the attraction.
New resolution: When I buy my own unit where I'm renting now, my kitchen with 42" counters will have a multi-use, 18" pedestal near the sink and a twin tub (and likely 3.0 cu. ft. Avanti) in the closet. This, of course, is in addition to my Roper Charm :-) Pics of said Roper attached.
Thanks again guys!
Hey, Todd (barcoboy)!
Nice to hear from you
I did not find -yet- my grand-mother's Hitachi (1970s twin-tub) but this little Sanyo/Kenmore is a little marvel in itself as it ''fills the bill'' and is so fun to use.
thx
uj
Kenmore 21300 by Sanyo
Aluminum tub with impeller and removable drain (this picture is from another similar machine)
Plastic molded control panel (note the thin aluminum plate under the three dials and the 'Kenmore' badge)
What it looks like under the thing...
-Pump system
-Circuit wires
-Rubber pipes
-Impeller (wash) motor - placed in a determined angle and driven by one A-31 v-belt (4L3xx @ 1/2'' wide)
-Beltless spin motor - direct drive mounted on four large spiral springs (much less vibration transmitted to the frame and cabinet)
NB in order to reveal impeller motor in more detail I had to brighten up things a little bit on one of the images as shown by the lighter rectangle on the picture.
