Magnalite cookware coding
luxflairguy
Mar 9, 2006
1,495
Wilmington NC
I finally asked Hans Craig a question he couldn't answer!
Can anyone here answer the coding on the bottom of Magnalite pieces?  My roaster is 4265-M.  The "Bay is filled with an assortment of pieces with all sorts of numbers.  My piece for example I see with at least 3 different letters after 4 numbers and a dash.  I see lots of P, C and T.
Anyone here have an hints or answers?
Greg
That do not know
My Magnalite pots/pans are all the old cast aluminum sort which are very heavy and thick. Whacking them with a mallet or hammer likely would leave a mark or maybe a dent, but don't think it would bang something out.
You place the pan bottom side up on a step and place a board across the bottom. You whack the board with a hammer to spread the force of the blow across the base of the and it was said to restore flatness.
Does this answer your question?
Pipe: https://www.castironcollector.com/numbers.php
From above link:
"Wagner called theirs "catalog numbers". Typically appended by a letter, the catalog number then identified both the item or model and the unique working pattern.
To someone knowledgeable about the manufacturer, it's easy to tell that a Wagner pan marked "1053C" is a regular skillet (105x), size #3 (xxx3), made from the pattern for it lettered "C". Wagner even let a mathematical rule apply when the size number became two digits. Sizes #10 thru #14 skillets were therefore inscribed... That's right, "1060", "1061", "1062", "1063", and "1064"."
