The 906 machines are fun but would be nervous using a machine that has a timer that’s rarer than gold. I think the reason why Maytag didn’t sell many 906 sets is they simply didn’t have the flexibility or options as the 806’s did since you could independently select the wash and spin speeds along with the temperatures you wanted.
I’d go through the dryer like qsd-dan said and try to find a new felt seal so you won’t have to worry about items falling on the heating element and shorting it out. Be sure to use a heavier weight oil such as motor oil for the drum bearing and use lighter oil for oiling the fan bearing, be sure to use grease to lubricate the reduction pulley shaft since oil will run off or will dry up fairly quickly on the reduction pulley shaft. Grease the slider so it’ll keep proper belt tension.
Make sure the tension spring is installed properly. If the tension is too loose it won’t tumble properly and will cause longer dry times. If the tension is is too tight, it will cause the oil to dry up quickly and will cause the blower bearing to start grumbling loudly and if you were to keep using it like that then it eventually cause the blower bearing to seize which is bad news. When the spring is installed the correct way, there won’t be any issues with tumbling or putting excessive stress on the blower/fan bearing.
