interceptor1985
- Joined
- Feb 15, 2012
- Messages
- 24
A few years ago my Godmother gave me her old matching Maytag's that she bought new and took very good care of them...anyways I recently replaced the belts, motor and cleaned it inside and out. The timer will run all the way through the cycles, and I did manage to get the tub to spin a little, once after I replaced the motor with a known good working unit oh and the trans is good, no signs of failure at all. no stuck undergarments around the tub....I'm just so confused on this, there is NO manuals to be had! Also...I'm looking for a new dial assembly the teeth on mine are very worn out.
and once I manage to fix these is there any mods I could do to this washer/dryer set? I'm in love with those old 60's Maytag's with the light up panel and tubs.
When I set it for a small load it does this...
Fill to set level
timer ticks on for a few min...
sticks fingers in ears and hums loudly to ignore my cry's to AGITATE!...
Timer ticks on some more...
Hums loudly some more when it comes time to rinse
tick tick tick...tub still full it did nothing...
tick tick tick
Hums loudly when it comes time for the final drain and rinse...
the end.
Fill to set level
tick tick tick
the end.
