Maytag A106 Project
Thank you,70series! I'm glad you enjoy my videos, I appreciate the views!
I've gotten a lot knocked out on this restore, but still a good bit to do.
good-shepherd, amazingly that sleeve came right off. No corrosion whatsoever! I couldn't believe it. That is the adhesive I had purchased, 055978 but it had already set up to the point it was unusable. I went ahead and used the high-temp adhesive I used for the dryer felt seal, and seems to have made a great bond for the damper pads. I let them dry for several hours, and then coated with the included poly-lube tubes.
I have had an unfortunate casualty, the oil cap for the main drive pulley. P/N 211038
It was very cracked up upon removal, and I didn't have high hopes of ever getting it back on. I was thinking it used to be more flexible, years ago, but it certainly isn't any longer. If someone has a lead, or an extra to sell, I'd sure appreciate it!
Here are a few pictures of my progress. I did make sure the lug was set correctly, too, in the 1/4-3/8 range! I started getting tired, so I called it a day.
Hi everyone,
Here is a full wash video of my Maytag A106 after reassembly, and being put back into service. It keeps running smoother, and quieter as all the new moving parts get broken in. I also finally located P/N 211038 rubber cap, and it should be here in a few days. Thanks again for all the advice. It certainly made the job go much easier!
Great job on the refurb, and an amazing video. Looked so much like the rough seas during wash and rinse that I could almost hear the Gilligan's Island theme. Well done.
Have a good one,
James
Thank you, Tim! I hope your '84 511 keeps on going for many years.
Thank you, James! Yep, the agitation is awesome. It was starting to have sluggish agitation before the refurb. You have a good one as well!
