Maytag A608 rebuild
remove the top half of the trans
Servicing the trans in place is not the way to do it, as can be seen from mess Tazz has already.
Once the outer tub is off the trans can be removed easily by titling the machine back and removing the lug screw and pulley.
I'm not real worried about the mess as I'm doing a complete rebuild but you are correct. I really wasn't expecting that much fluid in there either, talk about being over filled.
Still trying to find a transmission. After I cleaned up everything both sets of bearings for both shafts are pretty well used up. I'll post up some pics soon....
