Maytag Atlantis Dryer
llmaytag
Feb 19, 2010
186
Southern California
My mother called me tonight complaining that her Maytag Atlantis dryer doesn't seem to be working any more. She says clothes eventually get dry, but when she opens the door, she doesn't feel heat. Since it sounds like the they eventually get dry I'm inclined to think that it must be heating at least a little..if there was no heat it would take for every for them to dry from tumbling and air flow along. It's a gas dryer. Does anyone have any immediate thoughts on what I can check?
Please try all temp settings and all cycles to see if a contact in the timer has failed or the temp sensor has died. If you can see the ignitor, see if it is sparking or if the heat bar is heating up (glowing red) when the dryer is started.
May be the solenoids.....................had this on one of my Neptunes......at the start of the machine the burner would work fine, but half way thru it would not fire up, the glow tube would get bright, but when it came to the gas being released, nothing happened and the glow tube would go out, over and over, a repairman told me to grab and twist or take a screwdriver, and when the glow tube got bright and ready to ignight, twist the solenoids a little bit, then it fired up, once I released it the flame shut off....the slightest 1/16th of an inch offset would not let the valve work.......new solenoids, about 35.00, had it up and running ever since....
worth a shot......
SLOW TO DRY MT GAS DRYER
As with any slow dryer check the vent system first for good airflow, after that by far the most common problem problem on US gas dryers made in the last 30 years are weak or intermittent gas valve coils. This is a fairly minor repair and usually worth doing. All dryers should be disassembled and cleaned and lubricated where possible by a good technician every 5 10 or 15 years of use depending or the amount of use the machine gets, this is a good chance to have this done.
P S I would really ask her about her rinsing habits as over rinsing will make the clothes take longer to dry LOL.
Rinsing
Okay now Combo.....point taken about cleaning and lubing. Yes, it is a good opportunity. Peter is just teasing me because I rinse my clothes a second time and usually do so by starting another rinse after the regular cycle on the washer because the "second rinse" doesn't have a spin-spray!
Actually mom did confirm the airflow for the exhaust and actually had tried all temp setting and the timed cycles in addition to the Electronic dry. Repair man is coming out on Tuesday!
