Removed more wires. You can almost make out the high temp limit rating. I think it says 200-230. I had to test this one with a match. The hair dryer won't get that hot.
Snap ring, tumbler roller, fiber washer, and spring washer. Maytag guy here told me that the spring washers often make the rollers squeal, so I found a Mylar washer of the right thickness at "Ace" and replaced the spring washer with it and oiled it up with turbine oil.
Gave motor a complete going over. Took it off its mounting bracket and cleaned it everywhere. Carefully oiled centrifugal switch with turbine oil and got it working freely. Put motor back in same position as it was when it came out of the bracket and snapped the green motor clips back over the motor mounts with a wide bladed screwdriver. Take note. One side is for hooking and the other is for clipping. It takes quite a lot of downward pressure to pop those clips back over those hooks. That's why it's important to get the motor back into its original position as which it came out. It makes it easier to replace those clips. Oiled idler pulley and idler arm shaft assembly with turbine oil and greased the motor mount frame where idler arm rubs against it with heavy lithium grease.
Belt needed replacing. Decided to soak rollers in break fluid instead of replacing. The old rollers are made out of metal. The new ones are plastic. I soaked the rollers a couple of days in the fluid and they softened up a bit. Reassembled the rollers with the snap rings, fiber washers, and new Mylars from "Ace". Everything worked great.
