brisnat81
Hi Guys,
We've aquired a Maytag dependable care dryer, 3 heat settings, timed and auto dry for regular and PP.
The machine was absolutely choked with fluff, and I've found 2 SIM cards, $1.50 in coins, and a key that has cracked the plastic blower fan.
I've got the front right off, with just the structural support that holds the drum in place attached.
When I start the dryer, the motor is growley and then cuts out after about 5 seconds. After 5 minutes it seems to cool down, you can hear a thermostat click and then it will start again.
Before I waste my time tearing right into the machine, does anyone else think its likely to be the start switch on the motor, and if it is, can it be lubed and serviced. Is motor bearing failure a common issue with these dryers?
I look forward to any info you can provide.
Regards
Nathan
Regards
Nathan
