Oops...didn't see your question when I posted. On my '03 Dependable Care (which is lower-end with 4 water levels, no extra rinse, and no separate wash/spin speed selector dial; the cycle on yours might be different), the Permanent Press cycle has the same fast wash/spin speeds as the Normal cycle (I'm assuming on yours, it will operate at whatever speeds are selected on the dial), but the cycle progression is different. Instead of a short spray rinse during the wash spin, it does a constant spray rinse shortly after the tub has finished draining (similar to what the 1-18 does), and then it brakes for the rinse (labeled "Cooldown" on the timer, oddly enough). The rinse and final spin speeds are the same. I can't remember though, for the life of me, if there's a spray rinse in the final spin...but I'm pretty sure there is, though.
