Maytag Dependable Care
Underside of Top
Then two screws are removed allowing lid, backsplash, and top to tilt back(it is on hinges) allowing access to the lid safety switch.
A small wood shim holds the switch in place. Some twist ties[added after this pic] hold the shim up and in place.
A low-tech solution to a low-tech problem. No wire cutting, voiding the warranty, etc.
And the interesting thing is the fill flume directs the water over to the side of the wash-basket, making the two 15 second spray-rinses quite effective, IMHO.
As stated before, there is a a spray-rinse both before and after the deep rinse.
Get this---- there is even a spray-rinse after the 2nd (optional) deep-rinse.
Question???
Model #LAV3600AWW
Serial#17135664JT
Also additional#'s preceded by asian characters
3894B585(assembled in USA)
Does this mean that the parts come from somewhere else???
Gary, don't let this Maytag turn yellow. If you have a flourescent light, be sure that the tube is in a fixture that has a plastic cover. I believe the yellowing is a chemical reaction in the polymers caused by the ultraviolet light (someone correct me if I am wrong). The light cover will take the "shelling" of the light and turn yellow, rather than the Maytags turning yellow. You may also want to consider replacing any window in the laundry room with glass bricks, that help filter out ultraviolet light. Our Neptunes are still white and we have both a covered light and glass blocks, hope this helps. Bob
Already removed the fluorescent... :-)
Found 15w light-bulbs called compact ceiling-fan bulbs.
Fits into a standard night-light. Replaces 4w & 7w bulbs.
Now, there is plenty of light when the room is not in use, and no harmful yellowing /UV rays!
*GRIN*
gentle/fast
You might try leaving the speed control on regular (fast/fast) when using the gentle cycle to obtain a slow wash/fast spin. It works that way on my '97 Dependable Care. I discovered it by accident........
Chuck,
Bends down and kisses........
What a find! Just tried it on my new Maytag and VIOLA......that trick absolutely worked. Leave the speed control on Fast/Fast during the Gentle cycle and it achieves the goal of a slow wash and fast spin.
The things you learn here are simply amazing!
Thanks so much for the tip!
KitchenAid/Maytag GadgetGary
