lostmillenial
I'm new here and new to wringer washers and I'm looking for some help. My wife and I have been using this old maytag for a couple months with no issue. Recently it's been binding up when we throw power to it and upon closer inspection I see why but don't understand how to resolve the issue. Just above the shaft there is a clyndrical rod about the size of my index finger that pushes out against the belt and pulley causing it to stop turning. When I spin the shaft by hand, this rod will come out of the gear box and also retract (to a certain point) and it's motion is directly correlated with my turning the shaft. What is the cylindrical rod I'm refer to? What is its purpose? How can I fix this?
There is also some play in the shaft. It moves atleast 1/4 inch into and out of the gear box. Not sure if this is related.
The pictures show the belt pulley and the rod in referring to just on the outer limit of the pulley.
Thanks to anyone who can help.
