hippiedoll
this post is about the vintage maytag GA208 washer that i just got this past august...
everything seems to be working pretty good on it. i took the front panel off last night to get a look at the insides real quick & i noticed that the thin black hose that connects from the bleach dispenser (in the lower left hand corner) to the bottom of the outer tub, was unconnected up at the top where it connects to the actual bleach dispenser. so, i pushed the hose back into place, on to the little port of the bleach dispenser triangle "cup". no biggie.
but i have a question/concern. the water seems to pour/spray in, to fill the washtub pretty normally on the warm wash & the cold wash settings but, when it is set on the hot wash setting, the water barely even trickles into the washtub. is this normal? or is this because the hose that connects the washer to the hot water supply, has a smaller metal neck on one end & the cold water hose is the same size from end to end? or is there something wrong with my hot water wash setting?? can someone please tell me why the hot water barely trickles in when filling the washtub??
any & all advice would be greatly appreciated.
thank you so much.
thank you so much.
