sudsmaster
Here in Northern California the local utility company, PG&E, has been running conservation commercials. These are touting the fact (to an elderly man, in his basement) that customers can get a $75 rebate for replacing their old washer with a newer high efficiency model.
In the background I could see a harvest gold washer, with the unmistakable button pattern and faceted lower panel of a Maytag center-dial washer. The color bottom trim is blue, so I know it's a 606 or close relative. But the elderly gentleman's body is blocking view of the center dial. Finally, for a split second, he moves and there it is, a glorious center dial without the pilot light. So it must be... a 406 or lower end model. Anyway, although it's a shame that people are being urged to replace older washers with likely imported HE FL's, this also means that there will be more vintage washers up for grabs for us collectors.
