I've replaced the mounting stem on a friend's Maytag before. It's well-explained in Redcarpetdrew's thread from a while ago. I have a few lingering questions though.
If you remove the boot seal and mounting stem to oil the spin bearing, can you put it all back or do you need a new mounting stem?
I can't find the sub-part number for the old Maytag part #0A4298, the old-style seal. I saw a Whirlpool part float across my desk at work that looks like it, but I'll have to check my note at work in the morning. How would I use this seal in conjunction with a new mounting stem? Can this seal be replaced on an old mounting stem?
Finally, how bad does a spin bearing have to be to necessitate replacement? Another friend of mine has a very early Orbital-drive regular capacity Maytag (2-speed) and the spin bearing makes some noise as it gets up to speed, then quiets down. Should this bearing be replaced, or can it be oiled?
The joys of cranky machines,
Dave
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?25520
Dave
