pinkpower4
For those who want more control over their water settings, the information shown in this video also works for the Maytag mvwp575gw--the commercial residential washer sold in local appliance stores. You would then have hot (HOT) or cold only (any other water temp settings). A security screwdriving set would be needed to remove the screws on the washer's console and a flat head screwdriver or plastic tool that one might use to open a phone for gently pushing out the plastic tabs that hold the thermistor in place.
If you also add the appropriate APPROVED FOR INDOOR USE AND HOT WATER PLUMBING PARTS, one could mix a hot and cold line to the COLD while still having hot only to the HOT. This would provide a "warmer" warm and warm rinses--this depends on your water heater setting. For those who like fabric softener, how does that work with cold rinses anyway?
The information I can find suggests that the thermistor regulates the hot, warm, and cold water temperatures on this and similar washers by either adding hot or cold water to adjust the temperatures accordingly. Therefore, adding the mixer line ONLY without gently moving the thermistor to another location (as shown in the video linked) may cause error messages--where lights start blinking on the control panel.
Hot is just over 100 degrees F.
Warm is around 75 to 80 F.
The Normal (Eco) wash now becomes a lot more useful
. Hot is pure hot. Warm is warmer. Any of the other water temp settings is the mix of the hot and cold line unless a switch is added to the y mixer that could turn off the hot to that line when needed, but that is where is where even more caution is needed.
Disclaimer: One would risk voiding the five year parts and labor warranty and assumes all risks and liabilities. I have seen some videos where some have attempted to mix the hot and cold lines by using a y with switches on them that are for cold water only and outdoor use only. This is really risky and NOT advisable unless you really want a surprise INDOOR SWIMMING POOL some day! Anyone here with knowledge know of an approved metal Y or thoughts on the Y mixer hose made specifically for this purpose and for use with washer machines. Finally, anyone know of an approved Y with a switch that would work for indoor and hot water plumbing for those who need access to just cold water sometimes? What metal material is recommended? Brass? I would think they should be changed out on a regular basis just like hoses.
The clean washer cycle that one can only get to by using diagnostics and uses pure hot water does not work for washing clothes. It fills the tub in increments and does not really do the "wash" part of the cycle.
I do not sell or repair washers for a living. I am just a consumer.
What are your thoughts? This could be useful to people who do not want the new Speed Queen 2018 and newer agitub design that does not regulate water temp and has load size selector.
The older models Speed Queens, even the LWN432 models, are nowhere to be found in many areas. The only place I have seen them at is applianceconnections.com, which has several negative reviews through BBB. The authorized Speed Queen dealers in my area say they cannot get them.
Thanks,
Thanks,
