Maytag Revolution Hardcover
I hope it's worth it, too. But 8 cents shouldn't break the bank.
There are so many of those books on Amazon that sell for cents, and I honestly wonder how those dealers can do it. By the time shipping and Amazon commissions are subtracted (from the 8 cents, plus the shipping/handling charge), there can't be anything left. If anything, I'd think they'd be losing money.
In any case, we expect to see a full book report, fully describing the book, its theme, etc, etc, etc! (Just kidding! But do let us know your impressions of the book.)
Well, John, at least you did not ask the dreaded compare and contrast question.
Actually the acquisition of Hardwick, Norge et al was far from the high point of the company. It was more like the way the stern of a boat looks like it is rising up in the water as it goes over a waterfall. It shows that the authors knew as little about the appliance field as Maytag's directors did. All of those companies were up for sale because selling the factories was cheaper than modernizing them. Maytag bought broken down, dying factories and whipped the last bit of life out of them. Putting the Maytag name on the dreck that came out of the factories did not make the stoves, refrigerators and washers non-dreck; the Maytag name badge did not work magic. I remember the Admiral-made Maytag side-by-sides where it was almost impossible to have both doors line up across the top. This stuff gradually tarnished the whole Maytag name. Probably the die had been cast (thank you, Julius Caesar) when Maytag did not develop a true large capacity washer in the sixties when other manufacturers were doing so. Going for the quick and dirty route of badging Norge washers as large capacity Maytags was not smart.
Maytag's engineers and/or whoever controlled them were also complicit in the company's downfall with all of the problems experienced by owners of the early Neptunes, another Maytag product that received its reengineering in the field at a time when people paying a very large amount of money for a washer expected it to be more than a not-yet-perfected prototype; by the time the Neptune was introduced, automatic washers were not new appliances as they had been in the 1950s. When the user could not select Max Extract for a load of jeans because that option only allowed two attempts at balancing for the final spin instead of the 5 attempts with regular spin, they were pissed when it was finally explained. Then, when Maytag would not extend the 5 year warranty when the boards in Neptunes began going at just over 5 years, people swore they would not buy anything Maytag again.
In defense of Neptune
The Neptune was basically a sound design. It was corners that were cut in engineering/mfg that caused most of its problems. By the 3rd gen (5500 and 7500) the design had matured, but Maytag was still mismanaging the production, putting in substandard, poorly engineered components.
I got my 7500 set in the Winter of 2001. I also got an extended service agreement (total of 7 years) for both units. The dryer has never needed service, but I had the display replaced at 7 years because it was getting dim, esp when the dryer warmed up. The washer had a number of issues, resulting in a number of major repairs at the three year mark: drum spider support (cracked), motor and motor controller, main board. All of these were replaced with re-engineered components that have been fine in the six years since then. The only other nagging flaw has been the less than through powder coating on the underside of the top of the washer. It shows up as rust around the exposed edges of the dispenser opening. It's covered up by the plastic insert, and at one point I touched up the rusty areas with a good anti-rust primer. Still, I need to take the top off, wire brush it, primer and paint it, at some point. When I pointed it out at the seven year mark, the warranty repair guy refused to write it up because the rust wasn't visible from above. Oh well.
If and when the Neptune set dies, and maybe before that point, my next washer set will probably be the new Electrolux, largely because the washer door is reversible. Or I'll move the Frigidaire 3 cu ft or a Miele front loader into the Neptune spot. Again the Neptune gas dryer has been great, no real problems there.
Oh, and the 7500 washer doesn't give up after 2 balance tries on Max Extract. It will keep on trying for quite a long time before giving up. This generally only happens on odd loads, such as unmatched items like a very thick cotton bath rug (1" thick!) that weighs more than anything else in the washer when wet. Always I can reposition the load and eventually it balances and spins.
In short, Maytag's designers and engineers knew how to make a sound Neptune set. It was just the bean counters and poor management that ruined the product and eventually brought the entire company down.
I just received my copy from Amazon.com ($5.48 including shipping). So far, a good read and a very interesting history of the pre-Whirlpool Maytag. It gets two thumbs up from this reader!
