Maytag set saved from the landfill
heatgun215
Oct 10, 2023
3
Sacramento CA
I just purchased these two matching units, Maytag model A208 and DE408. The gentleman who sold them to me was in the right place and time, and the old woman who they belonged to was going to have them hauled away to the dump. She was the original owner and lived in a Streng Brothers community here in Sacramento CA. Streng bros built housing tracts that are very similar to Eichler homes. These are both in tremendous shape and functional. I plan on using them for all my laundry, replacing the new LG HE front loaders which I can’t stand using. My biggest concern is putting more wear and tear on them, being that they’re most likely all original. What parts should I look at replacing and what maintenance items should I check for? I have run 3 loads through them so far to check out all the functions still work. When I moved them I noticed the bottom of the cabinet had a build up of yellow grease around the edges, so I know some mechanics are leaking internally. Any help and direction is greatly appreciated!
Congrats on those machines!
I have that exact set (A208 washer and DE408 dryer) from 1978 in my collection, and they are my pride and joy. They were produced sometime from 1976 to 1980 (your serial numbers can be decoded for an exact date). In terms of maintenance items, the damper pads (the small pieces of felt between the base frame and the suspension tripod hub) are the main concern in my opinion. If they aren’t properly lubricated, they can tear away from the base, and allow the aluminum damper hub to contact the base, resulting in the damper being destroyed. This part is discontinued, and expensive to buy used. I would also recommend removing the screw in the side of the water pump and shooting some turbine oil into the bearing, and checking the condition of the belts on both machines.
Hope this helps,
Thatwasherguy.
Maintenance needed for a late 70s pair of Maytag
I would agree with post number four. The only thing to really worry about is the damper pads. You can look at the belts on the washer while you’re down there at the main drive belt if it’s badly worn, you can replace otherwise just use them and enjoy and see what happens you Can do as much harm as good by tearing them apart and working on them, especially if they’re lightly used machines they may not need anything for years.
PS, machines don’t get put in landfill anymore. These two machines could easily have made a new Hyundai for somebody, they do get recycled.
John
I was scrolling marketplace and found another beautiful set. This model is A107sa. I have not tested them yet, but the came out of a 95 year olds laundry room still used every day. I will have to determine which set I like more, and mothball or part out one or the other. Or should I resell a set? Wish I had the space to keep all of them.
The 208 would be more flexible with its 2 speed motor if you don't use the suds-saving feature. Also more water temp choices. Both have the smaller tubs in them but can swap in a bigger transmission/tub combo if you happen to locate a 3rd machine, lol.
