Maytag Washer Model A702 - parts needed
Transmission breakdown. Don't worry about drilling a hole through you workbench ;) I used a tall trash can to hold the transmission steady and upright.
You have 2 bolts and a cover plate on top of the pitman arm. In 1966, they went to a snap ring and square washer.
More trans disassembly and o-ring replacement. The best way I found to remove the o-ring was to use a dental pick and continuously pick at the o-ring in one area. Once the o-ring splits, it'll fall out of the groove. It's a time consuming pain in the ass, but keep at it!
This shows the top cover plate breakdown. Also this shows the identification between the different transmission gearing used in later small tub/large tub models.
Parts you'll need
22204012 Stem seal and boot kit (Purchase from Ebay)
Y0A4298 Agitator Drive shaft seal
204013 Tub bearing kit (Purchase from ebay)
210632 Transmission gasket
210286 Lower O-ring
211232 Tub cover gasket
211100 Lead washer (You'll need 3)
200744 Tub bolts (You'll need 3)
210183 Groove Pin for upper shaft. You may or may not need it.
210315 Fiber Pinion
Parts you may need:
211483 Splined washer
211484 Lug washer
205000 Spring/Glide kit for the sliding motor carriage.
Have fun!!!!!
AMAZING and a LIFE SAVER too!
WOW! Thanks for all of the great information! I really appreciate you taking the time to post these instructions tips and parts list since nobody I have found so far knows anything about these older models and or how to fix them. O.K. now I (think) I am ready for the challenge to do the repairs. I will photo document as I go through the process -which I expect will take some time - and then post them here so everyone can see the progress. I can't wait to get rid of the temp washer (Whirlpool WTW5100) ITS A NOISY ONE!
DOH!!
I forgot an important part #. Maytag transmission oil part #Y056080.
It would be great if you could photo document the entire process!
