Maytag wringer gulmite tool
at1316
Member
Aug 9, 2022
21
Georgia
Does anyone know where I can find the gulmite wrench for the tub bolts? Preferably without having to pay 50 or 60 bucks for it.
1946 E2L
Those stainless steel bolts and washers --
Are they exactly like the ones Maytag used in later model wringer washers?
It looks like each washer has some sort of rubber pad to go against the tub, but is any water seal needed between the bolt heads and washers? Or are the pads there mainly to prevent a corrosive reaction between the steel and aluminum?
That would be awesome. I'll be patient, I'd really like to save them.
This whole machine looks to be original.
As far I can tell, it's just a rubber like washer under each one.
Wow, looks like it still has the cast aluminum agitator.
There should be external oil ports on that motor (looks original) so it's easy to service without completely disassembling it unlike the later motors.
Yep, we love our teardown and repair pics. Not nosy, just interested.
So, the tub is leaking. Seal and bolts.
I'm glad yall are interested.. I may need advice 😂 as soon as I get the tool I'll start documenting!
Also, more info on this external oil port you speak of?
I read that about 2am a few nights ago. I took alot of notes on my notepad and book marked the page. Amazing re build.
Glad I found this site.
I actually have another machine just like this one.. serial numbers date them both coming out of the factory the same month/year. The other one is just in a little rougher shape. But it washes like a champ.
I was
Going to suggest you have a look at Larry’s thread but you have already!
Everything is covered in his thread for tare down and reassemble.
Keep us posted as to ur progress
Is this how they came from the factory? I hate to do this😣 but it is busted.[this post was last edited: 8/16/2022-11:23]
I went ahead and replaced the belt, triple checked, it is a legit replacement..
but it is too tight to run. Can the tension on these be adjusted? I have read til my eyeballs hurt and can't find the info I need.. or am just missing it somewhere.
obviously, I am not mechanically inclined, any advice is greatly appreciated.
