Maytag Wringer Washer
tarantulae
Active member
Jun 11, 2017
37
Colorado
Picked up a maytag wringer washer off craigslist today with the intention of using it for cloth diapers for my daughter who is just over a month old.
I read quite a few threads on here, and knew what I was looking for, but it was free, and "worked" so hard to argue. It has a lot of rust, and at first the motor stalled when I plugged it in. I realized the wringer was stalling it out, and after moving it around some, it was able to run.
The wringers are stuck turning in one direction, no matter which way the lever is pointed (at wringer, away from wringer, toward tub, away from tub).
I felt pretty good about diving into it to try to find what was seized up or causing the selector to not function. I took the wringer apart, and seperated the lower half from the drive head. The grease or oil that had been in there was solidified in a pancake at the bottom, with dry crusty bits along the bevel gears.
I'm in the process of cleaning it out, but wanted to know what kind of grease or oil to replace once I have the rust and gunk cleaned out. I read somewhere the wringer head gets 1/2 lb of some kind of heavy grease, while the lower transmission for the agitator takes something like transmission fluid.
I do plan to remove the lower transmission as well and replace the seal to the tub, as I suspect that failed, causing water to fill the transmission and oil to leak out. The back left leg is caked in oil. I'd like to know how much to refill the transmission with, what weight, and what to fill the wringer head with.
For gaskets, can I use RTV silicone when i reseat the wringer head? Is there an off the shelf seal that will work for the tub seal?
Thank you for any advice, I will work on getting some pictures tomorrow with daylight. I'd post the CL pictures but he was quick in taking the post down and I didn't think to save them in advance.
Duncan- First off...WELCOME TO AW.ORG!!
You will find out that the people here are willing to give you advice and aid you with your appliances whenever they have the knowledge. This website is worldwide and you can find people all over the globe who will too offer advice whether it's from personal experience or they have the answer you seek.
You can also find a lot of information in the "manuals & literature" tab that's at the top of the page. If you check it you'll find they do have Maytag service manual for wringers that will probably match to your machine. There is a small charge to download the info if you choose to use it. But the price you pay for that manual compared to a service call is definitely worth it.
Once you figure out the details just post your questions in the correct forum here on the site and someone will offer advice or assist. Best of luck with your new toy..
Washdaddy (Rick)
Maytag Service manual
Says to use Center seal grease 5616 (whatever that is) for most everthing with regards to wringer, and it's moving parts...Except it says to fill wringer head with 1lb of grease.. Says to use 56078 ?
Larry will probably stop by here and give you details on your questions for the power unit (transmission) and what kind of oil he used, can't remember off hand.
3 1/2 oz of power unit oil are supposed to be used in the cavity of the wringer post where the bevel gears mate.
Hang on help is on the way
Thanks for the welcome Rick.
Do the service manuals say what the grease is or just have part numbers like Stan posted? I can figure out how to take apart/put things back together, but if it doesn't tell me the weight of oil or type of grease then there isn't any point in getting one.
Stan:
I can find a center seal grease for sale in 4oz tubes, but it doesn't say what its made of. I'd rather find something usable that is commonly available from an auto store or something instead of special ordering things.
As for terminology, can you explain what you mean by wringer head, and wringer post?
I know the owners manual says to put a drop of oil in the bearings for the upper wringer every month. gearbox for the wringer which has the selector lever on top looks like it was packed with grease before, so I'm thinking that is the "wringer head".
But then you say the wringer post is where the bevel gears mate. It is a large area which would take more than 3.5oz of oil to properly lubricate. I'll grab pictures in a bit and maybe that will help with the terminology.
Duncan
You may be able to get most of what you need at the auto store or the auto section of WalMart, with maybe one exception
(the power unit) not sure if you can use 85 90 gear oil or not. The 3 1/2 oz mentioned in the service manual, may be the equivalent to the 1/4 lb soft grease mentioned below.
Hope this helps
Keep us posted
Thanks Stan.
I managed to get the tub removed today. Those old gulmite bolts sure pack a punch. 3 of the heads sheared off. (I was using a bolt extractor as I don't have the wrench for them, I plan to replace with 1/2 hex heads like the newer models have). I'll be removing all the rust from where the enamel chipped and then primer and repainting it all to get a nice seal again. I'm also planning to teardown the power unit and all the transmission to the wringer to clean up the rust and oil it all. While I'm doing that, I'll disassemble and clean the whole thing and repaint (I got inspired by e2l-arry http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?41892 (He happens to be in lakewood, not far from where I am, what a coincidence!)
Do you know if RTV silicone will be a sufficient gasket replacement instead of buying the kits? I'd like to special order as little as I need to.
I will use 90 gear oil for the power unit, and synthetic bearing grease for the wringer.
If I understand correctly, the 3.5oz oil goes in where the horizontal and vertical bevel gears mate. The 1/4 lb grease is packed in the wringer head. Does that sound right?
I'm still trying to find out what model I have exactly. My guess is post 55 as it had the black agitator, and it looks like my flywheel would support a pump if I wanted to add one? Do people sell those via the forums here or should I be looking at ebay and craigslist still?
K1428 is stamped on my power unit. GE 1/4hp motor. Red release handle, steel tub with enamel coating. Ideas on year/model?
I'm glad
You found Larry and that thread! He will be a great source of info for you. (Good move with the bolts)
If you've read his entire thread.. It's long but worth the read, youl find that he ordered gaskets, I think you should too. If I remember correctly there was some adjustment he made to get everything to fit right and not leak during reassembly. I believe your right about the 3 1/2 oz of grease, and packing grease for the wringer head.. But double check with Larry or Geoff or recheck Larry's thread (info is in there)
Yes yours will accommodate a pump. Youl most like find one one on eBay, and mostl likely it will be Phil from Ovid NY that has them, and offers them through eBay, as well as the correct gaskets, Think Larry added a pump as well when he restored his. Maytag pumps will make short work out of draining the water out. If you get one youl see what I mean. And if you have a sink or stand pipe for it to drain to, much easier.
I'd say 55 would be the year of manufacture for yours.. If you post your serial number, We'l decode it and find the month and year.
Take pics for us if you can, during your restore, we love pics.. Cuz we all want to be there to have our hands in it! Pics are the next best thing! I'm particularly interested in how you clean those gunked up parts.
Thanks Stan.
I can't find a serial number. Where would it be located? I posted all the stamped numbers I could find.
I'll double check Larry's thread and see what I can find on ebay for pumps. Good to know I have the right flywheel.
As you can see in my picture, 3 bolt heads broke off, so I am working on removing the remainder of the bolts and then its time to start cleaning!
Not sure
Where the serial # is located on a model N. On a model E, it stamped just below the crown on th back of the machine. So with your N I'd stand behind the wringer post and look to the left near the top of the body.
Someone who has a N may come by?
By looking at pic 3, I think I can see the pre drilled holes in the crossbar that will accommodate the pump assembly.
It has a lint screen (a little rusty, but what isn't on this one!) Its what made me think it had a pump originally.
I found the serial number. Stamped in the back at the top of the skirt.
3562390
Bad news
I think I'm out of luck now. In trying to remove the broken brass bolts, the centerplate has broken. No chance of making a seal now is there?
Is the centerplate replaceable or am I going to need a whole new power unit now anyway?
2 bolts broken still, one with a bolt extractor in it. Both go to the PU so the center plate won't come off. I'm not going to have machine shop EDM it out.
If I had started with quality extractors instead of trying to use the ones I already had, I would have had no problem. Once I got good extractors all the other bolts came out easy. Its just these 2 which I started with my old extractor that have problems.
Here's the picture of the serial number.
I'm going to look at another one on CL tomorrow. It costs money, but he says there's no rust in the tub and it all works. If thats true, I think I'll bring it home and wait for something to break before I ruin another washer.
You
Could contact Phil fir that part.. You would have anyway to get the gaskets ect. Or Dave at Dave's Repair he might have one. There are other source for parts ..
It won't come off. The bolts broke below the surface of the center plate but is still holding onto the PU. One of them has a bolt extractor broken in it too. I can't take the center plate off the PU.
At least
The price was right for it! And it may come in handy for parts.
What model is the one your going to see (square tub, round tub)
When you look at the one tomorrow.. There's a check list..
Make sure the agitator comes off and isn't stuck.
Look for holes in the tub
Look for think grease coming out of the breather hole in top of the right angle drive
Look for oil running down one leg
Make sure wringer turns and locks into position
If possible plug in and check operation of agitator (that it starts and stops when knob is pulled in and out)
If possible fill with water and check for leaks.
If equipt with a pump, engage it to see.
While running check to see if wringer rolls move in both directions
I'm I forgetting anything,
HTH and let us know
