Mega Miele?
ThatHomeSite's laundry forum had some information reagarding the upcoming Miele washer and dryer set. Have posted a bit of information in various posts here myself as well.
No one knows the MSRP as of yet, though there are some pundits making guesses over on THS based upon Miele machines sold elsewhere.
Voltage is 120v/60hz. Highest wash temp will be 170F, though not sure if Miele will require a 15amp or 20amp circut. Outer tub will be fiberglass instead of stainless steel, and IIRC Miele has broken down and this new washer will have a dispenser for LCB.
When speaking with Miele-USA tech-support about my current washer, queried about the upcoming units, and the tech said he had seen a model and while they are huge for a Miele, not as huge as say a Duet.
As for cycles,if the newest Miele models sold elsewhere are any indication, besides the usual programs, there may be cycles for duvets/pillows, shirts, and rinse/spin will make a return after being taken away with Miele last new washer series.
With 2007 only a few weeks away, you may wish to telephone Miele USA directly and see if they have any further information/brochures available.
L.
Thanks, Cimbi.
I've checked the Miele website and there is no hint of a new model.
I'm wondering also if the MM will have a right hinged door like other Miele's, or if it will succomb to the US practice of left hinging. If it's left hinged, then I will probably look elsewhere for a new washer.
Too bad about the 120 volt thing, also. This was a chance for Miele to really make a difference in high end washers. Instead I don't see how they expect to compete with an already crowded field.
I think in an "emerging" front-load market in this country, now is the time for mannies to push all things, practical to ridiculous, and try to grab market share.
It was believed that front-loaders would never catch-on here.
With big capacities, big port-holes and plaforms for ease-of -loading, this appears to be a non-issue.
Things change.
I went to Miele's website and clicked on Laundry Products, then Professional Laundry for the Home and the product list is quite extensive...capacities reaching 70lbs. Are we talking about the same new machines?
Well, Cimberlie, from that link, it's apparent that the Mega Miele will not be so big after all. The article states that the machine will be similar to the company's existing 60 cm wide line, and that means a 24" wide machine. Not much in the way of increased capacity is possible without going to 27".
And yes, the new machines will be 110 volt in an attempt to cater to perceived American preferences. What a shame.
On a brighter note, I was impressed with the HE2T I saw at Sears - no, Kmart - tonight. It's got a pure horizontal drum, decent capacity (3.6 IEC), and a clear porthole. Even more interesting, the door is completely symetrical in both X and Y axes. This means it *could* be possible to simply flip the door to reverse it. The only problem I saw is that a new hinge bracket might need to be designed, as the cabinet has a slight recess to accomodate the existing hinge. And, of course, the sheet metal would have to be cut in order to move the hinge to one side and the latch mechanism to the other. Nothing I couldn't manage - with an HE2T picked up for a song at a Sears outlet, that is ;-).
Sudsman:
Miele had no end of trouble selling their washers with only a 220v connection. Despite what many over on THS state, not every home has or can have a 220v line installed. This includes some of the most expensive real estate in Manhattan, where buildings from the 1920's to 1950's, those highly sought after "pre-War" buildings simply do not have enough power coming into the apartments, and sometimes the building to make a Miele possible.
Our Miele dealer told us he will have a sale up until they hear about the 220v power and or get an estimate for installing the required power. Spending $2000 or more for a W&D set is one thing, but adding another $3000 or more for a NYC electrican to install/upgrade the electrical wiring is just more than many are willing to pay.
With so many other front loaders on the American market,including the Bosch uber front loader, all running on 220v power; Miele decided to chuck lofty snob appeal and go for expanding their market share.
Early Miele washing machines sold in the United States, could on some models run on 120v power. My W770 does, as did some W1918's. Then as now, Miele was going for market share, and knew most American homes did not have 220v power.
Besides, today with few if anyone doing boil washes anymore, well besides Americans who just have discovered high temp washing and also share a maina for germs, (joking), a high wash temp of 140F or 170F is fine, and that can be done on 120V/60hz power. Faster if the circut is a 20amp instead of a 15amp.
L.
You could have both options
There's no reason why the machines couldn't be set up like US dryers.
i.e. use 110V for the motor + electronics
and then have an option of 220V or 110V heat.
If you've 110V only, the machine would just lock out some of the temptrature options.
110V / 220V options
There's no reason why you could have a setup like this:
Use 110V for the motor, pump, controls and electronics.
And have a 110V heater and a 220V heater in the tank.
If 220V is available, the software would simply make more heat options available.
If it's 110V only, you would be restricted to say 60?C and wash times might be a little longer.
Quite a number of European machines use software to cope with different specs for different EU countries.
i.e. most of continental Europe uses the CEE 7/7 plug which is rated 16A 230V
UK and Ireland use the BS1363 plug, which is only rated 13A 230V
and a couple of places seem to have 10A 230V plug/socket systems e.g. switzerland, australia and NZ etc.
So, in many cases they simply use software to restrict the max loading on washers and driers appropriately.
So, a dryer in the UK will take a little longer than a dryer in Germany as it'll be keeping below the max 13A 230V instead of 16A.
........or like a 60's US dryer move the bloomin' hot lead over to the neutral and VOILA your 220v heater now works on 120v.
[In those days there were few dedicated 30a 220v dryer lines or even homes (in the US) that had the voltage or ampacity needed].
You may need a resisor here and there to get the wattage and/or amperage "right" , but those curves are all very easily navigated, with a little forethought on the part of the mannies.
Toggles, many, if not most homes built in the 60s had the power for an electric dryer because, at least in the South, the newer building codes called for a minimum of a 150 amp electrical service and circuit breakers, not fuses. The fact that large areas of the Southeast were served at least in part by the Tennessee Valley Authority with a great deal of cheap hydro-electric power helped too. The TVA came along in the 1930s with the Rural Electrification Association and those two agencies transformed life in the poverty-ridden areas of the Depression era South. When my parents finished off part of the basement in our 1955 ranch style home as a studio apartment for my brother and me after our sister was born, the heavy up was almost free from Georgia Power if you bought either an electric range or dryer. I guess if anyone was stupid enough to switch from a gas to an electric water heater, it would have qualifed also. It had to be a 220 volt appliance that would be used all year so air conditioning did not qualify, but a heat pump would. The builders were either installing central air in upscale homes or knew that window units would be installed so that was another reason to have an electrical service with some extra capacity. A lot of homes were being built as total electric "Gold Medallion" homes even in places with a natural gas supply. Ah, to go back to the days when we were encouraged to find more ways to use electricity and no one voiced concern about demand exceeding capacity. Older homes in towns that had gas supplies had gas dryers if they did not have the capacity for an electric dryer. There were the home handymen who did their own wiring and arranged to have 230 volt air conditioners (the norm back then) and an electric dryer with instructions to the family to only use one ac unit when the dryer was in use. Laundry was done early in the day when it was cooler and it worked out if the house only had a 60 amp electrical service and a gas stove. By the very early 60s, at least where I grew up, new homes came with a 220v/30 amp dryer outlet in the laundry area. This was also the time when GE had a real lock on built in kitchen appliances because they would practically give the builder a built in dishwasher for about $10 with the purchase of built in electric cooking equipment. A new home with a kitchen that included not only a built in cook top and oven, but also a dishwasher, made a much better showing to people wanting a new home with modern features. The electric range and dryer outlet won the builders some breaks from the power companies also, so it really paid to make homes ready for electric dryers.
With the long drying times of a 115 volt dryer, new construction, remodeling, installation of air conditioning and other reasons for improved electrical service, not that many 220 volt dryers had to operate on 115 volts before the house had enough capacity to operate the dryer on 220.
I’m an architect who does mostly residential work, and in my experience homeowners really prefer gas appliances, at least in any higher-end construction. Right now one of my projects is a $400,000 remodel which includes a new laundry room. I showed a 220v outlet in the laundry room just in case someone would ever want an electric dryer or 220v washer, but the owner nixed the idea when he found that the additional wire and labor would add $100 to the electrical costs. For this reason even a lot of homes with plenty of service capacity don’t have 220 in the laundry room, so I agree with Launderess that Miele should concentrate on products that work on 120v.
As far as door swings go, I would LOVE to see someone produce a FL washer with a swappable door. Right now I have another remodel going with a new laundry room, but it is small as the space is constrained by a new breakfast room on one side and a fancy “outdoor room” on the other side with a spa, trellis, outdoor kitchen and fireplace. Needing to keep the exterior door to the water heater closet on an inconspicuous wall, I was forced to place the stacked washer and dryer against a wall to the right. This is all wrong for the usual left hinged door, which the owners know, but just can’t be helped. If someone made a left-hand front loader then I would happily recommend it in situations like this.
The owner of the second project has bought a set of TOL Whirlpools to replace her old Maytag set. Out of curiosity I asked why she chose the Whirlpools, and got told that she just called up her usual independent appliance store in west Los Angeles and asked what was the most reliable big capacity set. The salesman said the Whirlpools were was hands-down the best, even though they didn’t have both units in stock. I have no feel for this at all, but thought it interesting as that store carries a number of brands. I don't know if they handle Miele, but even if they do the capacity of the current units wouldn't have been adequate for this owner.
Very Interesting!
Awhile back posted a link to Miele's 2007 brochure for the UK. Correct me if am wrong, but the units featured in Westy's link look allot like the W4000 T9000 range.
Someone ought to write to this seller and get the low down. Or better yet pay him a nice litle visit, digital camera in tow of course. *LOL*
L.
Interesting, indeed...
Hmmm. Looks like the washer is on the right in that display. So I'm assuming/hoping that means a right-hinged door.
I would have to say, though, that sure doesn't look like a $2000 washer. Not enough bling, lol.
Regarding ease of making a dual voltage washer. American 220 volt circuits are a bit strange compared to European 220 volt. The American 220 has two hot leads, each one is 110 volts, 180 degrees out of phase with each other. Between them is 220. But you'd need not only a different plug but probably a whole new power cord to switch a washer from 220 to 110 and back again. Not impossible, just another complication to confuse salesmen (and we all know how confused they mostly are already). In other words, software alone just isn't going to do it. Plus the 220 plugs tend to be rather massive and clunky when compared to 110 plugs. Additionally, the current Miele washer is supposed to be hooked up to a 15 amp 220 volt circuit. Most US dryer outlets, if I'm not mistaken, are 30 amp 220 volt. Not that the circuit couldn't handle it, but there would be more protection against washer shorts if the circuit amps more closely matched the washer amps.
The europaen "220V"is derived from phase to neutral on a 3Ph 380-400V 3Ph "Y"circuit.the US 220V is a single phase-center tapped-exactly the secondary voltages of the distribution transformer.220V across the whole secondary-and 120V each side of the secondary to neutral or ground.I would think Miele washers could be built to run off a 15A 220V circuit.would give you about twice the wattage of 120V15A.15A 220V circuits are common for many types of workshop tools.also some treadmills(commercial ones) run from 220V 15A circuits.also 15A circuits may run some larger window AC units.NEMA 220V15A plug.I wouldn't think it would be too much trouble to put such a circuit in the laundry room.15A220V circuits are common in some home workshops to run power tool with 220V motors such as table or radial arm saws.I have run such a circuit in the past to run a radial arm saw.Used for tools with 1.5 to 2Hp motors.
OMG They've changed the place of the lintfilter in the dryer or am I wrong? If they did I think it's horrible. Normally the filter surface in the door is much larger and the lint is build up thinner so more air can pass through it. But I've noticed that with my Bauknecht dryer, where the filter is below the door, the lint is built up thicker and so causing a light clogging problem. Also I can't reach in the filter house so cleaning or getting coins out of it is impossible. Please Miele never get ride of the filter on the door!!!
