Miele Mechanical Timer Not Advancing
Exactly! My guess.
Rapid advance timer that works with impulses suposedly on the right works but normal clock timer motor on the left doesn't anymore, the tic tic tic clock sound is not there anymore as she describes.
So as I said I think the first thing to do will be to detach it and see if it works and turns, because if it does or both does and when you put it in does not that means timer inside got stuck somehow at worst broken.
Even though it is unlikely and it is a remote possibility is still is a possibility...and before contacting or putting efforts into trying to find a replacement motor I would do this test.
Thanks for suggestions and comments
Didn't want to mess about removing anything until have a clearer picture of what am dealing with overall. Digging into wiring and other bits of a perhaps nearly thirty year old washer where wiring hasn't been touched since things went in could be a minefield. Also since don't have a clue what am doing, just thought it best to keep "hands in pockets" for time being.
Yes, Crouzet is still around. At the time they supplied Miele, Thompson, Brandt and other European makers of washing machines, dryers, etc... with timers.
Their web cataloge still list synchronous motors from "82432" range as being on offer. But remember Crouzet was a supply vendor; they made these timers to supply Miele or whoever else to suit certain specs (cable length, connections, etc...).
https://motors.crouzet.com/customer-support/detailed-specifications-drawings/synchronous-motors/#
https://media.crouzet.com/datasheets/english/synchronous-motors-direct-drive-single-direction-syn
http://cdn.crouzet-motors.com/assets/library/Crouzet-Motors_Panorama_english.pdf
Crouzet like many other supply vendors likely never did nor does sell directly to consumers. But am going to reach out and see if they can supply information about where one might find anyone with supply. Though have a strong hunch they would simply say contact Miele (been there, done that), or another appliance part vendor.
Having spent hours combing various French, German and even Polish spares websites, parts for these 400 and 700 Miele washers are like finding a virgin at a prison rodeo.
https://webcache.googleusercontent....488159+&cd=1&hl=en&ct=clnk&gl=us&client=opera
Same problem with my Asko....It will wash, rinse, spin, etc...but the timer won't advance.  Mine just sits there and tick tick tick tick tick ticks away.  Asko used to sell replacement timer motors separately but I can't find them anymore and didn't bother calling SubZero directly since I found a complete timer assembly on ebay...just haven't installed it yet.
Launderess, it is just a matter of unclipping the grey metallic clamp holding the timer motor to the timer, you will probably find a star pin-spline on the timer motor as it was typical on miele machines no matter what kind of timer mounted if AKO or Crouzet, I have always found the same kind of pin-spline
My W701 even though mounting an Ako timer still had the same spline.
Unfortunately I think that surfing European spare websites will bring you to nowhere because of the voltage used here and no country in Europe use that voltage, perhaps you might have some luck in Japan (good luck with Japanese) or Latin America spares websites.
You may be lucky contacting Crouzet, I also doubt they sell directly to customer but maybe they can address you to some vendors and I looked at the map and there are plenty in the United States.
Looks like the "82..." or whatever starting with those two numbers are indeed 120-volt timer motors, I don't think they specially made a kind of timer motor only for miele or that particular timer and or others but that was on their catalogues at best they only put the star shaped pin to the motor spline, thing that you can take off and put in the new motor you will get that could come with a simple little spline.
A clock repair shop eventually if not you personally might be able to change it without probs and or crazy costs
Timer Motor For A Miele Washer
Good discussion, As already stated the two different TMs advance the timer at two different speeds, the fast one for setting up cycles and the slower TM for normal progression though the cycles.
Either 50 Hz or 60 Hz timers motors should work fine, if you use a 50Hz timer motor on 60Hz a ten minute wash will just be shortened to 8 1/2 minutes [ you will get your laundry done faster ].
A 208-240 volt TM will work fine here with a very small step-up transformer, conversely a 120 volt TM will work just fine on 208-240 volts with just a resister wired in the TM supply line, many companies do this on clothes dryer TMs.
In some timer motors you can typically only just change the winding and keep the rotor and its spline, rotor rarely fails, what usually blows out is the winding.
John US gas dryers in Europe and guess Australia or whater 220-240v place they will be exported to indeed use this system, speed Queen dryers have a toroidal transformer inside the panel that feeds timer motor, gas valves, igniter and heat and flame sensors.
Motors are 220v 50hz.
Whirlpool dryers instead have the transformer on the bottom between motor and burner, bad choiche IMHO as it gets covered in lint and might overheat even though they are usually oversized and way over what is usually required in order of watts. Very well made.
US washers timers are a different story
But I already thought ahead in case one of my machine's timers would fail
I will use a little step down by-passed for the motor.
I will get slightly longer cycles but I don't care...
"Unfortunately I think that surfing European spare websites will bring you to nowhere .."
Actually turned up a few Miele 120v/60hz parts in Europe from various spares suppliers. None of them what one needs and alas no timers, but never the less.... One place in France even had the huge double cast iron muet/motor (one side washes, other spins).
Suppose these people bought up job lots of Miele surplus or whatever, but I digress...
Playing around with Miele again today and watching cycle dial carefully can see and hear (know the sound) when it wants to move, but doesn't. Sometimes there is a slight movement, others it just sits.
Hi Launderess.
You may have found your own solution - that timer repair place. The website lists brands and Miele is on the list.
I wouldn't yet be 100% confident it is the timer motor. The fact that you can hear it "trying" to move suggests to me the mechanism might be sticky/jammed, rather than the motor failed. I'd give it a shot of contact cleaner spray, something like the link below. This is an Australian retailer, there must be an equivalent product in the USA. I have used this product several times, it is magic.
With <span style="text-decoration: underline;">power off</span>, give the timer a good spray.  Turn the timer dial fully round several times nice and slow, let it clunk into every notch before advancing to the next one. This will help spread the cleaner/lube product where it is needed.  Leave it for 24 hours for the spray to work its way into nooks and crannies. After the 24 hours, power up and give it a try.
If that doesn't work, enquire with the timer repair service.
https://www.jaycar.com.au/contact-cleaner-lubricant-spray-can/p/NA1012
Non Advancing Timer
Just connect power to the timer motor and see if the timer advances,
Spraying contact cleaner can help, but most often if I have a balky stiff timer I spray a good silicone lubricant in the timer and turn as Chris suggested above.
I probably have a used timer for one of these washers somewhere as we did part out a few of the many we have sent to the crusher. If I come across one will let you know.
Opposite issue with my similar age Miele
I unfortunately have the total opposite with my Miele w784, it rapidly advances through the complete cycle When you switch it on and won’t stop until it reaches the end Initially the timer just keeps going round and round but eventually it will advance through the cycle and the stop at the end. I have no idea what’s causing it, whether it’s the timer or something else.
Cheers,
Jamie
Thanks for suggestions and tips guys.
Heard back from Crouzet, they require information one does not have nor can easily find in order to possibly assist. Things like rpm, spindle diameter, gearing...
All this would have been specified when Miele or whoever placed orders, and obviously company isn't going to give out that sort of information, even if they could lay hands upon. With literally hundreds of permutations of timers "8243" it could be anything.
Meanwhile life keeps tormenting me; someone is throwing away a Miele W1065 on CL, but they haven't responded so assume the thing is gone. Why don't people take adverts down when things are NLA?
Of course can find period proper timer motors from all over Europe, but they are all 220v/50hz
Have found several NOS timers from same period (1980's through early 1990's), but they are all for dishwashers. Know the actual timers wouldn't work in my situation (incorrect cams, etc...), but don't know if the motors would suffice, and cannot find out either. MieleUSA is hopeless, and shan't be bothering with them again on this matter.
Have other things on my plate atm (like getting that huge converter wired up to power the AEG toplader), so won't be opening up the Miele again for now to get at timer.
Had another peep inside...
This time shut door so could start up washer (forgot Miele techs doing same on each of their (sadly many) service calls); to see what there is.....
First off to settle a matter of some debate on and off regarding age of this washer. Looking around timer for a model and or serial number and not finding any, had to get down on floor to see bottom of unit. There found a sticker saying something about seeing electrical chart for power rating; and date of April 1992.
According to various online sources Miele produced W1065/W1070 (sold in USA only) from 5/1982 - 03/1994. Knowing timer was made in 1992 means this washer could only have been produced between April of that year and March of 1994.
Assume electrical chart referred to is the schematic that should be just behind front door of washer. Miele tech once told us off because he didn't find it there, and accused us of tampering with washer or some such. One did locate the thing later upon subsequent nosing around inside but put it back. Now cannot remember where the darn thing is inside washer. *LOL*
One wonders if Miele didn't bother just making 115v/120v timers for what would have been a comparateivly small market for them at the time. But rather timer is "programmable" to accept power based upon various factors including ratings for timer motors.
With power on started machine up and right timer ticks loudly away and could see gears/cams inside timer rotate.
Left timer is rather quiet but now and then makes audible clicks; sometimes program knob responds (moves to next portion of cycle), other times not.
If one times those clicks, gets things right and manually advance timer cycle will proceed as it should, this especially on spin cycles. If misjudged timer will move "when it should" onto next portion of cycle. At least this happened when messing about with "graduated spin" cycle which does a series of 30 second pulse spins, stops, does a series of distribution spins, pulse spins.....
Maddening thing is Crouzet micro motor timers are avialable all over Europe from spares shops. But these obviously are all 220v/50hz...
https://www.hgt24.de/shop/timermotor-crouzet-p-1305.html?osCsid=t7nvlijkm0kv4boo3bk8qeb7u0
Can lay hands on NOS timers for Miele dishwashers from same period that have Crouzet TMs from same 8243 family. But don't know if one or both would work as replacements when plugged onto my washer.
On my W423 which is earlier, when the advance failed on the timer, it was a failure of the plastic gears inside.
Before you buy any parts, maybe just check whether the motor is still turning when commanded. You might find that something has stripped out internally in the timer and then all the palaver of finding a timer motor will not have been worth it.
Hi Launderess
You have opened the machine and are "this close." (Said in Maxwell Smart voice.)
Give it a squirt of contact cleaner / lube. (preferably a 2-in-1 product that cleans and lubricates, or just try a silicone lube product.
I strongly prefer a 2 in 1 cleaner / lube, as I said above I have found them to be magic. I even avoided having to buy a $300 brake light switch for my Peugeot car with a short puff of this spray - a bit of burnt muck fell straight out of the switch and problem solved.)
Just make sure the power is off, rotate the knob slowly a couple of times, leave it 24 hours, try it.
What have you got to lose?
As an aside, it is perfectly normal for one timer motor to be activated for very brief bursts.
Here's why:
There is one timer motor which runs a lot. It moves a faster gear inside, so it runs the alternating rotation of the drum during wash. It will have one cam that moves the contacts to reverse the direction of the wash, it will do something like (I'm making this number up) six cycles of left-right, then... its other cam comes into play, this cam will, after the set number of drum reverses, switch on the other timer motor to make the timer increment one step. Once the timer has clicked one increment, the second motor should turn off.
So effectively one motor controls the switching of the other motor.
If you have a sticky, dirty or burned contact, you can get erratic operation of the second motor. Not a motor fault, but a fault in power supply to the motor.
because this is a quick and easy thing to try, you should FIRST lubricate and contact-clean the timer. Only if that fails, spend time/effort chasing a replacement timer motor. Do the easy/cheap stuff first. (IMHO...)
Good luck with it.
Chris.
First and foremost would like to thank those who contacted me privately and or via this thread for all their kind words and assistance. Damn good!
Am going to set aside the Miele for now as nothing can be done until find another timer (NOS or used spare), My worry is continued use will simply cause timer to give out totally, then that will be that.
Have been on telephone and reached out to various places in Europe about timer motor. Crouzet no longer makes strictly 115v/120v 60hz timers, but they did have a dual 120v/220v 50/60 hz version. It is in very short supply and one would have to order about forty to get at them. 220v/50z versions everyone has both in Europe and USA, but that does me no good.
Miele USA is hopeless...
Apparently as of new year 2020 there was a major reshuffle of things and technical support (such as it was) got gutted. That department is staffed by persons who can do nothing more than schedule call outs, period. They seemingly no longer have access to part information or anything else. Days of having a tech walk one through diagnostic troubleshooting and or even installing parts are over. Was informed that such things "apparently caused more troubles than they were worth so Miele has stopped....".
It also seems MieleUSA has outsourced much call center activity to India, at least several calls were always answered by someone with that accent, so draw your own conclusions.
Before begin given bum's rush things were summed up as "your machine is old, over thirty years old; we guarantee parts for 15 years after production which is far longer than anyone else. Try finding parts for a Whirlpool washer that is over 30 years old....".
Responded didn't need to "try" as have NOS parts for a thirty year old Whirlpool washer right in my stash (ordered when had the harvest gold portable/convertible washer). Also fired back that unlike Miele Whirlpool didn't keep such a tight lock on spares so there were and still are plenty floating about.
In any event things seemed to be going nowhere with MieleUSA, so that door is closed. There is a promising German hobbyist website (Teamhack), but my language skills aren't what they should be.
Am not the first to deal with an older Miele washer that has timer issues, so that's me for you...
Will keep my eyes peeled and feelers out for used W765, W1070 or W1065 washer that can be harvested for parts.
W723
Thanks for suggestions.
Miele W723 is from an earlier model series than the W765, W770,and W772.
Miele actually made improvements and other changes to timer late in W700 range run for mechanical timer controlled units. Have the service manual which outlines some of them, and suffice to say even if the W723 timer would work in my machine (which it won't due to being 220v/50hz) there are some other differences that would need to be sorted.
Timer motors on that programmer are 220v/50hz as well; can find those new all over Europe. What I need is 115v/60hz.
When one gets down to things frequency likely isn't the largest worry. Things would just be 10% faster on 60hz than 50hz; but am not willing to possibly fry entire timer by plugging in 220v timer motors.
There must be a small transformer for electronics projekts thag could be used in this situation.
Dosen't have to be huge, only like a couple of watts.
Do you have an electronics part store somewhere around?
Or maybe online?
Thanks for suggestions guys......
Know some newer Miele washer do have small transformers to convert 120v to 220v, at least recall seeing pictures of such posted by a member. For my part don't even know where to start on how to wire such a thing into machine/timer, much less find a place to permanently affix so machine will close and operate normally.
Crouzet made these Programmschaltwerk timers (including motors) for a vast array of washing machines, dishwashers, and dryers sold all over Europe.
From what information have been able to glean from speaking with Crouzet and reading posts over on Teamhack what matters for timer motors is revolutions per minute, spindle, frequency/voltage and of course direction (clockwise or counter-clockwise).
Miele washing machine timers have "green" and "blue" gear wheels. You notice in above pictures timer motors have dots that match color of gear they are mated to fit. I do not know, nor have been able to find out if those colors mean anything. That is are all timer motors 82432 the same, and take their cues from electric signals off programmer; or are there subtle differences.
Need to find the schaltplan for my washer which should have timer programming on one side. Know it is in machine somewhere, but forgot where exactly. Recall finding it once after being told off by a Miele tech it wasn't where it should (had never opened machine prior to that event), but did locate it afterwards in another area of machine. Just cannot recall where, and am in no mood to open up that machine yet again to root about
Timers going wonky with these Miele units is common enough. A few members posted such issues going back (found in archives). None reported back however how they fixed the problem. Well one poor member ended up frying is W423 timer and had to rubbish machine in consequence.
If Father Christmas brings me a multi meter (am not buying any more new tools for duration, *LOL*), maybe once things are quiet over long winter will have both timer motors off to test. If indeed the advancing timer has gone, then at least know what one is dealing with. OTOH if that timer works, then have much larger problems.
Maddening thing is Crouzet made these entire 120v/60hz programmschaltwerk just for Miele to their specs. This explains why after Miele stopped ordering them in supply dried up. Spare part cost dear when MieleUSA had it in stock ($525 USD), but obviously people out there snapped them up.
