Miele Top Electronic W716
bellalaundry
Mar 8, 2007
661
Niagara Falls, Ontario, Canada
I've never seen this model before! Any ideas what era it's from? The ad says "direct from Germany". Makes me wonder if the electronics would work on 60htz?
It seems I can't download pictures with my new Chromebook...
kijiji.ca/v-washer-dryer/city-of-toronto/miele-compact-washer-hardly-used-excellent-shape/1488081602?undefined
That is a Miele from 1988 - 1990 or there about. It's a model just before the introduction of the Novotronic models. It's partly electronic, but the timer is still a rapid advance one. The dark control panel with the light controls is rare but I've seen it before. This machine was also available with a white on white and a grey on grey control panel. It's rather flexible because it has a separate temperature selector.
Neat!
Very nice looking machine! That one would be fun to have.
I have scooped up a few Miele’s lately. My oldest (a W1926) is 10 years newer than this one. I would guess it was made for the North American market as it’s in Canada, but who knows until you ask. They are all built in Germany., even my most recent thats 6 years old.
Kevin
PS, my cousin-in-law and her family now live in Niagra Falls, ON
Mum has a variant of this one that I got from Rodney. Louis is right, its incredibley flexible, Mum's also has an additional knob to select spin speeds from 400 - 1300. When I got it, it just needed a new Heater relay and new motor brushes.
The only issue with that timer, is if you cancel during the wash, the time it takes to click back to the start, so that you can select another cycle. you have to do a full cancel and reset before you can pick another option, even if you were to go from a wash program to a drain. It gets cranky if you dont let it do its thing.
Go for it, you're just what that washer needs.
Besides you know you want it! *LOL*
Hardly used could mean someone got it to North America, found it didn't operate well on 60hz power and thus it has sat sitting ever since.
To best of my knowledge Miele North America (USA and Canada at least) only began importing with the W770 washer and matching dryer. Then came W1065/W1070 models, all of which obviously are younger than machine pictured above.
We both have AEG Lavamat washers that somehow made it across the pond but otherwise were never sold in North America. In fact we also both have ironers and other goodies that came from Europe, so what's another washer? *LOL*
Contact Miele Canada in morning to see if they can give any information on washer. Things like if it ever was sold in North America, technical specs, etc..
You want to find out if this washer is 50hz/60hz or 50hz only. That and if it is bothered by running on 60hz.
The AEG Lavamat I lost out on was older than this machine, or maybe same age, but owner claimed his ex-wife used it all the time and it wasn't bothered by frequency difference.
Unlike modern Electrolux AEG washers there likely isn't a pesky motherboard in this washer refusing to let it operate if it senses incorrect frequency.
Worse that can happen is timer, motor and maybe some other bits would run 10% faster on 60hz power.
Direct From Germany
Means just that, washer was made in Germany and somehow made it over to North America.
Again reaching out to Miele Canada will tell if machine was ever sold on this side of pond. Having never seen anything other than than W770/W765 washers was told those were first imported to these shores. But have been known to be wrong before....
Your only main worry about this machine is Miele Canada won't have some or any parts nor can (or will) order them from Germany.
The W700 series washers predates W1070/W1065 and Miele USA (and one assumes Canada) long has stopped importing spares from Germany as machines are past 20 year life cycle spares guarantee period.
Of course if spares are needed you've only to find proper part number then plug into internet to see if can be had from Europe or elsewhere.
Would recommend if going to collect in person check/listen to motor. Am almost sure that machine has same huge cast iron double motor as in our 1070. Long as it is good should give you years of not decades of service without issues. Replacing brushes is a bear of job but doable.
I'm sorry Launderess, but the W716 is of a newer series than the W1070/W1065 series. I don't know why Miele used the W1000 numbering, I know them as W770 and W765 as they were named in Europe. But the higher numbered W700 series is older than the lower numbered W 700 series. (I know, not everything Miele is logic). The W765 is part of the New Miele Class that was introduced in 1982. The W716 looks like an early model of the generation next to that, introduced in 1987, at least that is the oldest brochure I have of that generation in my collection.
I’ve got two in this range. An entry level and a w723 1300rpm model with speed increments of 100rpm
Both have the modern square motor, the difference is more sound insulation on the higher end model.
I have a W784 which is similar to the 400 series from the 70s
Edit
Looking at parts lists, it seems to be that the 700-719 models are a hybrid of the high 7xx models vs the mid 7xx models. Anything could’ve slipped in, depending on what was left around. [this post was last edited: 2/21/2020-15:10]
lucky/unlucky owner of the W716 referred to in post
Hi all,
I actually purchased the unit being discussed above. Unfortunately, it did not run at all on 240 V. My husband switched it to 120 and it started filling - and promptly stopped. It is now stuck in the on position! I was sooooo lucking forward to using this machine, not only because it comes from my parents homeland, but because I love the idea of a machine that actually washed clothes properly. Any ideas who I can call to find out if it's possible to fix it?
Peg
Unless something is different that machine should require 220v/16 amp circuit at 50hz. Max draw is 3.2kW (for heater), something you are not going to get from 120v.
Some older Miele washers aren't to picky about frequency; that is they will run on either stated 50hz, or 60hz (latter with or without issues), but switching from 220v to 120v normally isn't possible except in certain instances.
Here in North America early some early 700 and 1000 series washers could be switched to run on 120v from 220v. Miele supplied a power cord kit that either their tech or yourself (if handy with electrics) installed.
It could very well be that certain bits inside washer work well enough on 120v, but others need the required 220v. Your best bet would be to examine the electrical schematics for washer. This bit of paper should be just inside service panel in front of washer.
You can also use schematics to diagnose why washer may have had issues with 240v power.
Definitely 220v / 50hrz
dropping to 110v was to check the electronics. which all worked. it is currently wired on a 240V circuit, 3 -wire with two hot and one neutral. the blue and brown wires are hot and the yellow/green wire is neutral. there is power to all wires, HOWEVER the power light does not come on and none of the settings work. Miele professional was not able to assist on a 32 year old machine
Uhm
Not sure
But green yellow will most likely NOT be a phase.
Green Yellow is the earth connection color over here.
Brown is phase, blue is neutral over here.
Given you want to get 240V out of 2 phases you will have to put both phases on the terminals, no neutral there, right?
So your phases on brown and blue, green yellow on the earth.
My best advice is to disconnect the machine IMMEDIATELY and to NOT PLUG IT BACK IT until you fixed that.
Maybe send a picture of the connections plus what kind of supply exactly you want to connect it to.
Better Picture
So if I understood,
Yellow Green Stripe goes to Ground (copper)
Brown goes to Hot (Black)
Blue goes to neutral (white)
Our home is 100 amp
The Breaker is 2 X 30 AMP
Gosh - with self Isolation, I could really use from fresh laundry...any help you can provide would be so greatly appreciated! :)
As machine was never sold in North America Miele North America (USA, Canada, and Mexico) likely have no information other than what can be pulled up in their systems. It is likely certain you won't find a tech or customer support person who even knows what this machine is much less ever worked on one.
Sometimes you luck out and get an old school tech or support person who is up for the challenge and will work things out, others cannot and will not be bothered.
Last time one inquired to Miele about appliances brought here from Europe, but never sold on this side of pond response was "Miele will provide worldwide support for their products, but if you want repair work done it is not guaranteed or carries any sort of warranty".
This can understand as it is a bit much to ask people to fix a machine they've never clapped eyes upon. That being said usually there are only subtle differences between what is offered in North America and Miele appliances say in Germany.
In general however Miele North America is washing their hands of appliances that are thirty or so years old. They no longer import parts for W700, W1070, W1065, and even some early W19XX series washing machines. Good luck getting a tech that even knows what these early machines are. Miele stopped training new techs on "older" appliances years ago.
It looks as if your washer was hardwired, something common enough in Europe, but on this side of pond we are used to plugs already on cords. You might want to consult a qualified electrician to assist sorting out how to either put a plug on this washer or how to hard wire it into what you've got.
While assume it is possible but haven't heard of a washer that would only run on say 240v, but not 208v or 220v. Looking at Miele washer internal parts and or electrical plates normally they read "208v-240v" power range.
For the Canadian side of things I can't really help you.
For the machine side I can tell you that it needs voltage between brown and blue, something in the range of 200-250V AC.
Yellow Green is ground.
What that matches up to on the supply side I have no idea.
I had a Miele washer that had a water sensor flood protector on the bottom which would disable the machine. I unknowingly triggered it once when I tipped the machine on it’s side for transport and some residual water migrated to it. The machine failed to work until the water on the sensor was dried, then it was good to go.[this post was last edited: 5/1/2020-20:11]
Alone for the weekend
So I am on my own for the weekend. I have limited experience with wiring, but have built lamps from scratch and attached wall and ceiling light fixtures and such. Is there any harm in connecting the wires and flipping the switch. I just checked the following sequence:
Blue goes to neutral (white).
Not even a power light. So disapointed, although I'm guessing my husband would have tried this the first time he plugged it in. Interesting how the power light comes on at a lower voltage.
Thanks everyone for your support.
OK I read a bit into some stuff
So if I am not mistaken, each phase (so each hot) is 120V to neutral.
So to get anywhere close to 240V you have to go phase to phase, no neutral.
So you have to take 2 DIFFERENT phases and put one on blue and one on brown.
They can't be the same phase twice.
