Miele W1215 free parts
poeta4546
Oct 11, 2024
0
High Desert, CA
Localed in the High Desert in California. Was going to fix my W1215 because of drum out of balance and rubbing. Initially thought it was a bad bearing but after removing the rear arm bearing spun fine. I can see chalky and powdery stuff around the spider bracket so more than likely corroded and cracked. I was going to take it to the dump but if someone is interested in taking it as is disassembled for parts, you're more than welcome.
Only thing that broke in the process is a tab on the soap tray, that holds it onto the metal frame. All other parts are working fine.
