Doorseals
Hi Louis,
My 2515 doesnt have a door seal there. The boot just presses up against the glass. The older boot seems a better design, although harder to clean, but the water just seems to run straight back into the tub. It retains even less water than my new machine does.
The old one seems to have a rubber liner between the glass and the door frame, that is the component thats hard. I didnt want to push my luck and find out if it was brittle too
I figure the issue with the dryer is one of two things.
1) If the machine has a pressure switch that controls water level, via inlet and pump, the pressure switch has failed.
2) If there is no pressure switch, the pump simply has failed.
Due to the amount of sand in the cabinet/filters/drum. I'm guessing there could be a fair bit of sand in the condensor system. Its a tiny pump, about the size of peach, so it could just be blocked. Otherwise the dryer seems fine. Unlike most reversing dryers I've seen, the heater and blower fan run, when the machine pauses to reverse. The joy of having 3 motors I guess.
The other door seal around the edge of the door on the dryer is brittle and crumbling (And full of sand) the inner one around the filter is just loose and hard. These machines dont have a lot of access for service. I so far havent figured out how to get the top off the dryer, there are two fragile plastic clips, as the parts are NLA for the lid, I'm not game enough to force it. It does appear that the back will unscrew, but until I can see what I'm disconnecting, I'll leave it on.
From underneath, the dryer is a complex maze of tubing and ducting.
Its bizzare getting used to an appliance that you can infinitely control. After only having a new FL machine, the most unnerving thing, is when the timer clicks over an increment there is an inital loud roar for 2-3 secs as the spin motor gets up speed and then its gone from a tumble to 900RPM spin in about 5 seconds and sounds pretty much like any FL machine, but perhaps slightly louder. So far with 5 loads, I havent managed to get it OOB, it came close an a really full load, but ones the speed got up there, it was fine.
Thanks for your interest Louis, I appreciate it.
