launderess
Well here's me thinking today would be an ideal time to get a bit of washing done and generally caught up on housework.
Not a bit of it.
My "vintage" Miele washer (W770) has now decided it will not spin at high speed (1100rpms). When the timer reaches the portion of the cycle when it should commence speed increase from 900rpms to 1100rpms, the drums stops and one hears nothing but the pump going. Soon enough the timer advances out of the cycle and the machine shuts down.
Tried a few tests, and while the machine will complete a cycle with the spin speed button switched to the lower speed, when the higher one is selected things go as above. Indeed switching the switch between the two speeds while the timer is located in the "fast" part of the final spin will start and stop the spinning, but at 900 rpms.
Kicker came when switched the machine over to the woolen cycle, which uses a fast 1100rpm spin for 30secs as the final spin. Nope, the machine would not cooperate. Darn thing kept the timer in the low section of the spin, then advanced to close out/end the cycle.
My weak knowledge of these matters tells one that there is a motor control problem, or perhaps something else. Either way it means a call to Herr Miele and opening my purse wide for a service call.
Then again, one perhaps could live with 900rpm spin. After all there is the Hoover twin tub spinner, which holds about 4kg and spins at 2800rpms. Could go even furhter and have a spin dryer sent from across the pond. The large Miele or Frigidaire models hold nearly 5kg, which is the same full load as my Miele.
L
Not a bit of it.
L
