Am here to tell you
My 1070 will certainly spin if and or when there is water in the tub. Know this from several times in past having advanced the timer while machine is draining once that portion of cycle "timed out", washer went into spin. Don't know if it would have continued as always stopped the cycle.
While having electronics have found the 1000 series at least sold in USA are only just better than fully mechanical controlled washers. Yes, they will try to balance and redistribute loads, but when the timer says "Right Then!" and moves onto the next portion of cycle, that is what will happen. This probably explains the heavy/robust build quality of these washers. Miele certainly knew or and or expected a certain level of unbalanced spinning with heavy loads. Especially when you consider these washers do not spin loads at all until after three rinses.
One of the first things that went wrong with my Miele was it wouldn't spin at 1100. If that speed was selected machine would simply stop when timer reached that portion of cycle. If switch was set back to 900rpms or left there from the start, no problems.
https://www.google.com/?gws_rd=ssl#q=Miele+w1070+won't+spin+site:www.automaticwasher.org
Miele came out and tech was able to get the machine to spin at 1100 by moving some wires. However that is when the messages began about "machine is old" "had brittle wiring", etc... began coming from MieleUSA. In order to source the reason why machine wasn't going into high speed spin would basically require taking out the motor and other bits, then tracing the problem via wiring diagram. It could have been many things said tech; relay, poor connection, etc.. But they flatly refused to have anything to do with removing motor/testing. Even my independent Miele guy wouldn't touch with a barge pole.
Since these machines lack self diagnostics the only real way to find out often what is wrong is by "going in" if you will. Then one applies a bit of Cat In The Hat logic; to find out what something is start by finding out what it is not. Speed switch, wiring, relay, electronic control, motor brushes, etc..
