Even Breville will conk out after a while. I had the temerity to clean the inside of our convection toaster oven with Easy-Off. Nope, the metal is evidently aluminized, and you know what lye does to aluminum. And the fan bearings are getting noisy. Now, we use it a good bit, still, they're $350 compared to $35 for an Oster. I doubt you'll get 10 Oster lifetimes out of the Breville, though they do look nicer. And I wouldn't spend $500 for a new commercial Sharp MWO, but I would buy a used one that hasn't been used too hard. Probably get one for less than half the price of new, better still if you don't have to deal with a used Commercial Appliance dealer.
In all honesty if I had to choose between this:
https://www.amazon.com/dp/B085P3GCJT
and this:
https://www.amazon.com/dp/B00BDF5ZNS
I would choose the Sharp. The Breville as nothing more than a standard junky residential microwave with fancy electronics, sleek outward appearance and soft close door while the Sharp is more robust and still has a whisper close door.
Because the Sharp heats MUCH more evenly on high power than the Breville, there is no need for fancy power levels, inverters and sensor functions.
