hi Larry
It's really not complicated at all
but to tell you the truth I would avoid going there unless you have to! Think of it like "your the Doctor and it's the patient" First do no harm LOL
For what it's worth...
It just dose'nt make sense to me that you have to "assume" that water has gotten into the PU without hard evidence!
Since the motor works and there is still a belt turning the agitator, why not run the machine, (motor and belt) for an hour or so.
(cant hold water now anyway) and see if anything leaks out of the weep hole, and listen to how the gears sound. If it sounds O.K and there is no seepage, then lets "assume" that water has NOT gotten into it!
If your prepared to do a tare down now, then you'll be prepared later. Do you see my point?
If it were me, I'd go ahead and get a new agitator, your going to have to anyway if your going to restore it later!
(and keep it a washing machine)
In the mean time, patch the holes to make sure the tub holds water. Then run the machine and see! There is nothing lost at this point. If evidence shows up later, that water IS getting in, then you still have'nt lost anything, because you were ready to do a tare down in the first place.
Even if water has gotten into the PU, it still may not be necessary to "rebuild" it, more like cleaning and refilling with the correct gear oil.
(if you could see inside, you'd see what I mean. Not much to go wrong in there)
I'll try to email you a PDF file of the service manual. (if you want) If that dose not work then I'll be in touch to snail mail it to you on a disk.
I understand that having a pump on it may not bother you now, because of the floor drain you have, but you should know, if you don't already, that one can be added in the future without a lot of effort. Phil has them. I think for about $45.00
Sure wish this had gone a little easier for you, but they are fun little projects!
Let me know
Stan
Let me know
Stan
