How do you like your Dremel Multi-Pro by the way? I've several Dremels, but not the Multi-Pro.
It's the only one I've used, but it usually gets the job done.
In your first picture the "shaft" sticking up appears off set, but I can't tell. Or is the large gray cylinder above the wash and spin clutch plates a tranny that makes it work?
Jed the wobbling is produced in that bearing housing shown in the first picture. The outer housing is attached to wash shaft, the inside of that housing is offset to produce the washing action. The shaft in the center is the spin shaft.
I am curious though - you mentioned that the seal was something that you were able to sub a replacement for easily. May I ask what source you used and how you determined which would work? Thanks!
Its a simple lip seal Ben, these are easy to find. I brought it into Gopher Bearing and they measured it and ordered it. Lip seals aren't as effective as carbon face seals but that is what was in the original machine design so I knew a new one would work just fine.
Have you made a suds cake or suds-locked it, yet?
Nope, no suds cake in the machine, it bounces those suds right over the top of the basket and down the drain during the wash cycle.
