I've always had a soft spot for BOL machines, especially older ones. After being inspired by Robert's Hotpoint (epic find btw), I saw these on HD's site, and much to my surprise still electo-mechanical
http://www.homedepot.com/p/Hotpoint-Front-Control-Dishwasher-in-Bisque-HDA2100HCC/205350188
http://www.homedepot.com/p/GE-Front-Control-Dishwasher-in-White-GSD2100VWW/202868433
Portable is also being considered, but not yet finalized
http://www.homedepot.com/p/GE-Porta...-Place-Settings-Capacity-GSC3500DWW/203248875
However I do not agree with the lengthy cycle time, redesigned wash arm/circulation system and the reduced water fills. (no thanks) Fortunately the molded parts like tub, escutcheon and door are nearly identical to GE's older machines.
I plan on installing a new timer in the machine
http://www.repairclinic.com/PartDetail/Circuit-Board-Timer/WD21X574/271566?ss=-x67736435303064&mr=1
And detergent cam
http://www.appliancepartspros.com/ge-cam-wd16x301-ap2039370.html
To mimic the old 50 minute 11.5 gallon wash and long 35 minute dry on the 80's machines
http://products.geappliances.com/Ma...l/Dispatcher?RequestType=PDF&Name=49-5337.PDF
I read the reviews and a lot are complaining about poor drying which I can see from a shortened or cycled drying time.
The wash system will also be changed out, though I need to research the new pump design further... The drain solenoid on the new design only has one spring instead of two. After playing around with a GE dishwasher 9 years ago when the new design first came out, I discovered that the timer pauses the motor after each drain in order to close the drain flapper. Obviously something that wont work with the old style timing, but I am not to disappointed
http://www.repairclinic.com/PartDetail/Pump-And-Motor-Assembly/WD26X10013/820985
New pump design FWIW. Looks similar but something looks off...
http://www.repairclinic.com/PartDet...X10051/1811038?ss=-x67736333353030647777&mr=1
Sump, hub, grate and wash arm will also be updated
http://www.repairclinic.com/PartDet...ly/WD35X10011/771153?ss=-x67736435303064&mr=1
http://www.repairclinic.com/PartDetail/Sump/WD18X213/2478?ss=-x67736435303078&mr=1
http://www.repairclinic.com/PartDetail/Sump-Cover/WD12X418/270715?ss=-x67736435303064&mr=1
http://www.repairclinic.com/PartDetail/Sump-Cover/WD12X417/270714?ss=-x67736435303064&mr=1
If everything turns out well I may go a bit over board with a potscrubber cycle
http://www.repairclinic.com/PartDetail/Switch/WD21X516/271489?ss=-x67736435303064&mr=1
I am not sure about the water valve's flow rate on these machines, but time will tell. I know GE's BOL and MOL water valves from the early 80s up until 2008ish all had the same flow rate, so adapting one to the new machine will be no worry. Only thing I am unsure about being GE selling separate wiring harnesses. I only need a terminal block that physically fits the timer and has wires that grab all the needed terminals. I might have to dig into an old machine for this, but if I can order harnesses separately or terminal blocks let me know.
Let me know what you think.
And detergent cam
