my maytag dryer saga part 2
What’s wrong with your Maytag DG606? Btw, I don’t think there ever was a Maytag HOH dryer made in a 607 model.
Maytag85
the pilot light will not stay lit
it takes over an hour to stay lit
But once the dryer is started 5 minutes later the pilot goes out but the dryer continues to run
also the blower is making a racket
I replaced it as the cost of parts and labor would add up to a new dryer
if the parts could even be found to fix it
If I ever have these problems, it’s going to get fixed. Not going to get rid of a fine piece of machinery over something as simple as a pilot light, belts, thermostat, or dry blower bearing. Have taught myself how to work on the Maytag HOH dryers, read through all these archives and still look through the archives from time to time to be sure. Maytag HOH dryers aren’t going to regenerate or repair themselves like Christine the 1958 Plymouth Fury will.
3
I got a Maytag dg608
it is identical to the de808 dryer that matches my Maytag a806 washer
except for gas vs electric
console
and the color of them
but
I am going to have to relearn to use a dryer like this cause I have not used the 808 in about 15 years
I have good dress shirts I need to dry and need advice on how to set the dryer
"I am going to have to relearn to use a dryer like this cause I have not used the 808 in about 15 years. I have good dress shirts I need to dry and need advice on how to set the dryer"
On my DE808 dryer, I have the timer dial set to "Regular" and the button switches set to "Regular Temp" and "Normal Dryness" 99% of the time. I use the "Extra Dryness" button when drying throw rugs since they are very thick cotton ones. The dryness sensor placement on the SOH dryers are located in front bulkhead and it's not in the ideal location like the HOH's which are locating in the baffles, much larger in size, and always in the path of the clothing.
Timer motor issue is probably stripped gear if it's a Kington timer motor, or seized gears if Mallory. Respond with the part# on the timer body and we can help guide you to the repair.
Your 606S was birthed in December, 1974.
Regular temperature, regular cycle, and extra dryness should be sufficient. the Perm Prerss cycle has a 7-10 minute cooldown that is longer than the regular cycle cooldown, thus taking advantage of residual heat longer.
