My new 1963 Whirlpool Imperial Mark XII set
I guess I’ll have to look more into what it’s not turning on. The drum and ozone light come on when you turn the timer but doesn’t do anything when you press the temperature buttons since the start buttons are combined with the temperature options. Strictlybojack said it ran when he tested it but it’s not wanting to work for me. Could be a loose connection somewhere and I am getting power since the drum and ozone light come on
The rear part of the belt shifter is broken off. I can technically still get a normal and super speed drying temps on it but it won’t shift the belt to the other pulley and reducing the air output from the blower/fan
Took the ‘63 Whirlpool dryer apart this morning and one of the wires that goes to the door switch came undone. Should work when I test it again this evening.
Only thing that won’t be working is the belt shifter but it sort of will work since it will only have the 4500 watt element on and will switch on the other 1000 to 1500 watt element on the super setting.
Tested the ‘63 Whirlpool dryer last night and it works! Gets HOT on the super setting so this definitely has the 6000 watt element in it
Easy Two Speed Spindrier
First post here, new to the group. Wondering if anyone knows the exact year of this old Easy Two Speed Spindrier. Very clean, and everything works. Grabbed it from Aunt Edna's basement a few years ago with some plans to use it, but now would like to sell to someone who can appreciated it. I haven't seen a thread about Easy spindriers on here since 2018 so sorry if this was wrong place to post...J
Reply #53
Not sure what the exact year of you Easy machine is but my guess would be late 50’s. Don’t know very much about Easy machines since I have no experience with them but there are a few other people on this site that know more about them. Only machines I have experience and are familiar with is Maytag and Whirlpool belt drive machines along with a Whirlpool direct drive I once owned 3 years ago and those are all the machines I have experience with using
That Easy Spindry . . .
. . . is the most fun washer to use.  I had one I loved for years, but the pump bit the dust and I had no way to replace it.  Gave the machine to Tyler and he found a pump.  Hope he's enjoying using the Easy.
Jerry Gay
The older style of wig wag is a bit louder than the newer style of wig wag that came out sometime in the mid to late 60’s but it definitely gives this machine character.
