Softener/// spin speeds
Dave; Dry or powdered softner is mostly avail. to commerical users only. and in min 45lb quanity One would most likely only need a teaspoon full or less in a home washer.. but as stated above Getting help from Ecolab or any other companies will be non existant as they will tell you that you are not to have the product anyway.. The dry softener will not harm a home washer, I have used it for years in the smaller washers and at home too. Only have to use 1/4 teaspoon here. Ecolab AutoChlor and P&G commerical and most of the others, Will flat out tell you on the phone (and be nasty about it too) that they don't care if you damage your clothes or washer you dont have it under their contract so too bad!
SPIN SPEEDS are 1200 RPM and the basket is a full 52" so we are talking some serious G forces on these machines..They are vibra mount (soft mount) machines so they can handle a out of balance load pretty well. They do have a balance proceedure they go thru before going into extract and it all but stops the unblance problem. Have not yet had one to go out of balance. If they sense a out of balance load they stop and redistribute the load and start again automatically. It will tell you on the screen what it is doing so the washman knows.The programmer can be programmed to the second and temperatures to the degree, There is nothing that cannot be programmed or added or deleted. A operation can be skipped or added at any point in the cycle , Temps can be raised or lowered at any point. levels can be raised or lowered at any point also. Wash time can be added anytime by the second, min, or even hour, a soak can be done for any length of time anywhere in the cycle.Extract time can be shorter or longer by the second or min. with only a touch of a button.
