More investigating today
I removed the agitator today and saw what appeared to be a brown encrusted mess. The oil leak didn't look as bad as before and I wiggled the shaft looking for play and didn't notice any at all. Looks like a snap ring and washer to replace the seal so I'm going to try to source a part number online. I did wire brush the corroded locking ring clean. It will need a good soaking in Kroil before trying to remove it. I did rock the tub side to side and there is a definite knock to it. Gonna need that tub bearing I'm thinking its that bad. I may as well change both bearings, bushing and top seal as well as clean and replace motor slides and springs which those will happen Sun then the correct timer when it arrives. All that other stuff along with spanners I'm going to start acquiring then spend a few hours tearing this thing down. Let's see if these pics load this time.[this post was last edited: 12/26/2015-14:27]
