Well, I don't have any pictures, however it is simple to do. All you need to do is get the clothes basket out of a Busted Topload washer or take the cylinder out of a bust Frontloader(these are plentiful) since the cylinders in FL machines are SS and the clothes baskets in SQ/Amana machines are SS they won't rust when placed outside in the weather. I had a teacher that would come to my house to collect them when I would scrap machines. The baskets and cylinders have plenty of holes for water drainage, however the openings of the FL cylinders may be a little small. Another issue with the cylinders the shaft. You can either cut it off or stick it in the ground. If you have issues cutting the shaft off you can have metal shop do it for you. Getting the cylinder out of a busted machine is quite easy. You can take your frustrations out on it first(how much you paid for it and it only gave you 3-5 years). Since that tubs are plastic, you can tear off the plastic, remove the pulley, try to remove the cylinder from the bottom plastic piece. For clothes basket, remove top of machine, take off slashguard, remove agitator, remove agitator drive(if one), remove spanner nut(special tool required), remove basket. Some baskets are attached by a series of hex nut at the bottom of it.
