My new zanussi fl812!
Sorry for the delay. Part number 50103850009 is the thermostat you require. It is available here: http://shop.electrolux.co.uk/product/50103850009/THERMOSTAT+NC40 I've used Debor glue before, but haven't tried Fido's method. I would add that it's very important that no water drips onto the motor.
The parts diagram can be found here: http://procornerpdf.electrolux.com/static/Pictures/Views/U0P09/361.PDF Beware that it covers three models so make sure you match the part you need with the correct model.
I also have the instruction manual as a PDF, if you would like it I'll send it in an email.
Tom
Also, make a note of any wires you disconnect so you know where to put them back, and be sure to remove the mains plug from the wall before doing the work. Of course this is mainly common sense!
Tom
Hi, very nice machine, I love the look of the grey panel.
I have an FL812V which is very similar, here is a picture of mine when I've get it:
Now it is almost fixed (installed a new door handle and cleaned some parts), but it is leaking by the drain pump filter cap, I bought a new cap and seal, but there are a few different versions and of course I got the wrong ones!
Here is a picture of induction motor with its large pulley, this machine uses a small (but reliable) electronic control unit for soft start to spin:
I love this motor design because you get the best of both worlds:
Induction motor, so no need to brushes, so better reliability and lower noise.
Electronic speed control, so high spin speed with soft start.
Thanks for your help tom.... Parts and the glue is ordered! Not sure if I need to order a new seal for it?? Looks like it has one on the diagram? Are they all standard? I'll take photos of the wiring before I start! Looks a simple job!.... I say that now lol😜
Statomatic looks a nice machine! Does it have the same drum as mine? They seem similar but with a different case and control panel! My machine def does not mess about when it comes to the spin,One of the things I like about it! Not waiting days for it to sort the clothes out! Lol
Lamont
Hi Lamont,
I hadn't thought about the seal. If you get the seal out and it's in one piece, not perished and doesn't look too distorted it should be OK. But I guess it might be worth changing at the same time.
If the fix works on your machine, I will give it a go on mine.
Statomatic,
That's a very interesting machine. I've never seen one before with that later styling but the enamelled outer tub and original drum. It's also the first I've seen with an electronic module linked to an (old style, not inverter) induction motor on a Zanussi.
According to the technical information, the FL812V was made in the Alcala factory in Spain. Sadly, this closed a few years ago, but I read that a lot of tools and equipment from the production of the old range were transferred here from Italy in the early 90s. Many of the UK marketed Tricity/Bendix machines were produced in Spain, alongside the Zanussi "Delta" range. By this time they'd switched to a plastic tub and different drum, but other internal parts remained the same for a while.
Tom
Having done a bit more reading, it is necessary to insert a small flat bladed screwdriver between the seal and thermostat edge to remove the stat but leave the seal in place. You shouldn't need to remove the seal unless it is damaged and needs replacing.
Tom
@tom, yes it is made in Spain.
There is a few Whirlpool washer/dryer (made in Italy, by Ignis I think) with this induction motor/electronic control design.
The tub is not enameled, it is stainless steel:
Had it on again tonight with a new door seal and I think it was at 40 degrees! Or dam near it! Am thinking it's maybe because it's not been used in a while! Which one would I be changing if I was to change it?
Lamont
The 30/40 stat is the one with the white and orange spots. If it is working fine then I'd leave it. Keep the spare one just in case you need it in future.
Did you find the door seal change easy? The retaining spring that joins the seal with the tub can be difficult to fit.
Tom
My pleasure Lamont! Great to hear that the new thermostat did the trick and you managed to fit the new door seal. If you need any more help with it in the future please let me know.
Here is my FL1123 from 1985.
Tom
Hi Lamont.
welcome to the club and congrats on the new old machine.
Lovely machines, 80s Zanussi's - very solid and reliable.
Am picking up one tomorrow, but don't know if its an FL812 or an FL1012. Only find out when I get there - am hoping for the latter, as I need it for a project.
Owned a WD1012 until a few years back, until we passed it onto Lavamatjon. We bought it from the back of a scrap lorry for a tenner and, though fully operational electrically, someone had holed to outer tub:-( Still usable, but the tub requires re-bunging every now and then.
Paul
