Yes, I assume it was a typo and you meant dryer?
Dryers are simple things in the mechanics, whether commercial "normal size" like the ones of this kind, new or old or "fancy" they works pretty much the same way...
I see this one has a timer drying, not automatic sensing "auto cycles", so is without thermostats who detects when laundry is dried by hotness level..but you've to set what you find to be the proper time according to load quantity and type (just matter of getting used to), the "fancy" (supposing you meant the electronic) speed queen IIRC did put moisture sensors instead of thermical which if correctly working makes sure that machine will shut off a little bit more precisely than heat sensing, heat sensing may result them in running a little bit longer than actually needed for certain loads ...but not that Big deal IMO..moisture sensors are around from ages anyway.
Uni.macs are speed queen made and as they claim they use about the same parts both for domestic and commercial machines, with a few differences I noticed but not big ones.. then surely parts seems still available and if I may say you can find parts for dryers even older than this..
Whether made from Raytheon or alliance Speed queen I see parts are plentily available for the dryers...I have raytheon made speed queen set and can find pretty much all the parts in stock, even because at that time of raytheon made speed queens many other brands such as Amana and Maytag shared parts...as Amana was bought by raytheon, who sold to global Goodman something who sold it to Maytag.....
Uni macs are good dryers, if it works I don't see why you should change it if you're not bothered by time drying, unless you want a specific dryer looking differently for mere aesthethic reasons, then that's another matter...
Remember also uni-macs and alliance aka commercial speed queens are sold all over the world, if there has to be a large stock for parts it's for them...[this post was last edited: 1/23/2015-18:34]
