Need a new washing machine and need your help.
I was wondering about the Maytag build quality. Does the transmission have plastic gears? I assume the Speed Queen TC5 has metal components in their transmission.
And most LG washers are now assembled in the USA. Their factory has been up and running for almost a year and a half so any bugs should have been worked out by now. There might be a few models that are still made in South Korea.
I have the Maytag mvwp575gw...
and I haven’t had any issues with it in the two years I’ve owned it. Unlike some people here, I am not brand loyal. Also, many people here trade out washers like most people do cell phones. Not me.
The SQ TC5 is probably the overall good choice if budget isn’t a factor. Where I live it can cost anywhere from $1K to $1400. Some things that may make it worth the extra money are it has NO ATC, half load options for all main cycles, and probably has the best build quality. If you buy it, buy it for that. It isn’t going to last like their old models, but it will probably last longer than most news ones on the market today. This board has a lot of people that can get parts for cost and can do the work themselves. BUT most consumers cannot afford to or have the knowledge to replace the bearings. This is what I think will limit it life. Unlike their older models, this model has two control boards. One is behind those knobs and another works in conjunction with the transmission. Finding those model-specific boards later could be an issue. It is my understanding this is a time-limited model that will only be sold through 2020 (unless this has changed—new energy regulations are supposed to take effect which this model won’t meet. I do not know if that is still true.). It’s odd that SQ only backs it with a THREE year parts and labor warranty. Some folks responding may have gotten it while it had the ten year warranty so are not considering that new purchasers won’t get that. The transmission is covered for 15 though. I think most folks will get about 15 maybe 20 years out of it. That’s just a guess.
I have the Maytag mvwp575gw. SQ only had its TR series when I needed a washer two years ago. I think it is probably the second best overall choice but best overall choice when it comes to cleaning. Not only do the tub and agitator move separately but so do the top and bottom. Clothes move in, down, and through the water well. While the TC5 does wash clothes good, this agitator design makes a difference when it comes to heavier soiled clothes or bulky items to work them through the water and detergent better. The main quirk with this washer is its only half load cycle is the normal eco. It works great for quick washes and smaller loads other than delicates. It is also the ONLY cycle that adds some cold even when hot is selected. I just found a way to manually add hot. While it does have a spray rinse, it works surprisingly well! Want a half load rinse, just run Normal cycle again only don’t add detergent the second time. You will still be under an hour. If you buy the mvwp575gw it has a FIVE year parts and labor warranty. Although the build quality is not as good as SQ, the design makes some parts easier to replace. This model is referred to as commercial by Maytag and shares many of the same parts with other models which may make them less expensive and easier to find later. Although I don’t think its a true commercial washer, it does have a better build quality than Maytag’s “commercial technology” models. There are a few people here that say they’ve had issues with them, but I haven’t seen this anywhere else. Every models has some lemons that make it off the line. The belt is thicker, the capacitor is a higher watt, premium bearings, 1/2 instead of 1/3 HP motor, etc. Just wash like items with like items, and I’ve had no issues with balancing. It does have ATC. It is supposed to add warm to cold to maintain a minimum temperature, but it also means the tub fills by alternating hot and cold. I would rather not have that. I think it will probably last around ten years. I paid $750 for it.
They have some budget Amana and Ropers that have the dual action agitators as mentioned by another poster. Be sure to take a look at them too. They run in the $400 to $500 range.
If a matching set is important, there is no justification for the higher price on the SQ dryers. Maytag and Whirlpool seem to make some very good ones for less.
Finally, take a look at the new LG top load with the agitator referred to in one of the recent posts. This one may be one to watch.
Take the time to view videos on YouTube by both Lorain Furniture and Kirk Rivas. Keep in mind reviewers have to be careful what they say since they sell these products (companies actively try to control what is said about their products, reviews, etc.), but the videos speak for themselves. I hope this gets you pointed in the right direction to choose what works for you.
I have the Roper RTW4516FW and I’m very pleased with it.  It has lots of flexibility, is reasonably priced, quite, fast and cleans/rinses very well.  If you select the Deep Fill option it has rollover equivalent to the best of vintage TL’s.
I use the Normal/Regular cycle on Auto Sense Fill with Hot water for almost every load.  It fills with an adequate amount of water to clean everything very well and uses a spray rinse, and finishes each load in 34 mins.  For Bulky items I use the Bulky cycle, and it fills right to the top, will handle a kingsize bedspread, comforter or blanket or two king pillows with ease.  Even though the spin speed is only 700 rpms every load dries on high temp in just about the same amount of time as the next load takes to wash, 34 mins.  The Bulky cycle takes about 60-65 mins, mainly due to the extended fill times for the deep wash and rinse.
I’ve been using mine now for 15 trouble free months, and I’d buy another one if need be.
Eddie
https://www.lowes.com/pd/Roper-3-5-cu-ft-High-Efficiency-Top-Load-Washer-White/1000074111
Same here ea56. The Amana version is the same machine. I mostly use normal also and can get straight hot water just by turning off the cold faucet but it will also give a hot rinse if I forget to put the cold on right after the agitation starts.
I was in Best Buy earlier today and saw my machine there. The model number on the store model is NTW4516W0....on mine it is NTW4516W3. I wonder if this is the 3rd revision of this model and if so I would like to know what Whirlpool changed.
Bought washer
Hi all,
Tried to follow some of the advice I received here and here is what I ended up buying.
I looked into the speedqueen/Huebsch TC5 but I think the capacity was too small for large comforters. I ended up getting the maytag mvwp575 seemed the best of bad choices, I needed something simple to operate as well, do to a resident senior in the household, whom would also need to use.
Anyway that's for the washer, the dryer is a different story. I don't really care about matching the set but it seems most of the maytag dryers have a similar complaint.... they don't dry your clothes in a single cycle. What's the point in meeting power consumption regs if you have to run things through twice to dry them?
Another issue I am having right now, is alot of manufacturers are having supply/inventory issues... and we can't get certain products up here in Canada right now with what is going on. The washer it seems was the easy part, and even that can't be delivered until Oct 21st. I thought I found a dryer that would work for me, but the soonest delivery date is dec.16th my horrible driveway will be impassable to a delivery truck by then...and even then apparently that order coming in only has one of the model I was interested in and no guarantee that I would actually be the one getting it!
So I am left trying to buy one that is in stock locally and not having much luck.
At Coast Appliances locally here they have a speedqueen dryer in their scratch and dent list,but the model number they list can't be right as I can find no information about it when I google the number.
The number that they provide is model# spedxrgs153cw02
I find it strange they list it as a speedqueen, when speedqueens are sold as huebsch here...
The list says it is a commercial dryer original list price $1600 cdn, marked down to $999. I don't know what to make of the model number though.
I might end up having to keep the GE dryer from the original purchase, at least I know it dries the clothes in one go, even if overall it is an inferior product.
It's hard enough to find products that work the way they are supposed to and add to that supply/inventory problems right now and it is nigh impossible.
I have a Maytag dryer and it dries every load in one cycle.  Never heard of a problem like this before with a Maytag dryer.  Its the BOL model from 2015, been using it for 5 years with no problems.  And it was only about $429, a good bargain.
Eddie
Maytag mvwp575gw...
I love the simplicity of the controls on this washer. They are just right for the type of loads I do. Powerwash, Delicates, MIxed, and Bulky work just like I would expect them to.
As stated earlier, Normal Eco works great for all types of loads except Delicates (wash action is too rough) for small and quick washes. The only real quirk is I have to find a way to add hot for the loads of small whites I do. Maybe I should look more into Tide designed for cold water washers for that??? One thing I forgot to mention is that if you use any options with the Normal cycle like a presoak or extra rinse, it turns it into a regular cycle. What I mean by that is you will get a deep water fill. If you chose extra rinse, you will get TWO deep water fills. Hot will be a true hot too.
I love that I can wash any load even with a presoak in under an hour, and that there is plenty of water. My college kids literally bring home a car load of laundry at times.
This washer fills the tub by alternating between hot and cold. When I have selected hot, the main cycles use tap hot for the entire fill. I can get a very warm by turning the temperature to hot for the first part of the fill and then using warm for the remainder of the fill. When I need “warm”, warm as is works fine.
If you ever need to service under the control panel, it requires removing just two screws. Most other service parts can be accessed under the washer or by removing the front panel. One of my kids left a chain in one of their pockets one time that made its way through the hole in the bottom and was headed toward the pump. I am an extra small adult. I just propped the washer up, slid under it, and was able to disconnect the portion between under the tub and pump to retrieve the item very quickly. Seriously, the hardest part of that repair is that I am getting older and that I my eyesight isn’t what it needs to be. The kids have left a few coins that managed to escape my checks. So far, they remain in the tub instead of going under the agitator bottom, so I have been able to retrieve them without taking anything apart.
I have been very happy with the performance of this washer. Our clothes look and smell clean. As a side note, I had an LG front load before this. It works well for small items, but dirt actually came out of a comforter I had washed on a regular basis in the front load when I first washed it in the Maytag—I mean the water was brown! Front loads just don’t seem to work as well for bulky items because they cannot work them down, in, and through the water as well. For that reason and because of ease or repairs, I don’t think I will go back to a front load (even though I had a good experience and that one lasted ten years before the bearings went out). I am still using my old LG dryer that is probably 12 years old now. The old front load I had was supposed to spin as fast as 1200 rpm. I haven’t noticed a significant increase in dry time even though this Maytag washer is only supposed to spin at 700 rpm. The loads I have washed have all dried in under an hour when set on the appropriate setting. My sensors no longer work, so I have to use “timed” setting. I later bought a Panda spin dryer (Look at Laundry Alternatives Nina soft dryer too). Love it so far. Had reduced dry time for most cycles to just twenty minutes and 30 for the heavier fabrics. I also notice a decrease in my electric bill :-)
I am so thankful I came across the reviews I mentioned in a previous post. I looked at the wash action for the washer I was going to get and this one, this ONE is so much better.
I hope it works as well for your situation as it has mine.
