I removed the top portion of the porcelain bulb socket assembly and detached the wires from its base. Whether I tug on them from that end or from the open end of the pipe, they won't budge. These are solid wires (maybe 16 gauge), not stranded. There is no doubt in my mind that the socket base will shatter if I attempt to remove it, and I'd like to avoid having to. I think the entire porcelain assembly is still serviceable and can remain, if I can manage to replace the wiring while the socket base is still attached.
The only thing left to determine is whether the 3/8" section of pipe is permanently fused onto the fixture. I didn't want to get carried away trying to loosen it. There are old tell-tale scars visible on it from a wrench or pliers but there's no threading exposed, which is why I'm wondering if it could have been intentionally fused in place for safety concerns associated with gas fixtures. Re-wiring would be a relative cinch if I could get this piece off.
Since I've never worked with a gas fixture before, I don't have any knowledge of how they were manufactured, or what degree of damage I could do by using more force to try and remove the pipe stub from it.
Also, before I started pulling things apart, I clipped a power cord onto the wires and screwed in a bulb. I plugged the cord into an isolated test circuit on my bench, flipped the breaker and the light lit. I at least know now that there are no breaks in the wires if I get to a point where I'm able to use them to fish through new ones.
Is it time to take this thing to a pro yet, or should I keep at it with trying to remove the pipe?
