Well, the whole neutral goes where idea is 1) To protect humans and 2) To lessen chances of shorts.
In the first case, the neutral would be placed on theaded portion because it's the biggest and most human accessable portion of the socket. In the second case, it's also the part that MIGHT be more likely to contact the metal body of the fixture and maybe cause a short to ground. But it would only be slightly safer and then only when the fixture is powered on with a bulb in the socket.
If you flick the light switch on, and then check the voltage differntial between each wire and ground, the wire with zero (or close to it) potential volts would be the neutral wire. The one with 110 or more volts would be the hot wire.
Volt-ohm meters are relatively cheap; one can often pick one up for free from Harbor Freight with the right coupon. Even so, one that will tell you what's up with the wiring will cost less than $10.
Naturally you need to be careful around live circuits.
