mark_wpduet
@ Jonn
I didn't realize you had a Maxima - Anyway - My duet is before FL machines started having designated clean washer cycles - I later found out mine has one built in but you have to enter a sequence to get it to work - I only use LCB when using the clean washer cycle. It fills with a LOT of water and rotates the drum really FAST, almost literally spinning with a tub full of water (both directions) - the ONLY problem with mine is it doesn't use HOT water, only warm....so it doesn't do as good of a job as later machines with some built in ones. I don't even think the heater is even active in mine during the clean washer cycle.....I hardly ever use it anyway, but I have used it a few times. It's pretty wild to watch. Good to know about the machine cleaners and not using too much.
