redcarpetdrew
Tub bolts from Hell (usually...)
I have to second Jon's comment. During my time as GE service way back when, I came to HATE those bolts. A real pill. Good for you that yours didn't fight!
Fixing the tub is very viable option. I've done that with a few. It seems to me that there was a repair 'patch' just for those occasions. Clean and dress the rust area (usually on the sides) and then apply the patch which became one with the tub. Maybe my memory is fuzzy but I DO remember it. Gemline, maybe?
If you can, try to clean and reseal the drain port and such @ the tub bottom. Another spot for rust to rear it's ugly head.
Also, check the lower transmission drive pully seal. If it's weeping, the lower seal is not to much of a headache to replace and I *think* it's still available. It's pretty much a lip seal that contacts with the drive pully shaft and a whole lot easier to service with the transmission out and upside down so the bottom cover can then be removed and seal replaced. It was a common repair for me to do...
Nice machine and looks to well on her way to a permanent place in your laundry room (or at least until the next pretty face shows up...)
RCD
RCD
