NEW Arm and Hammer "Essentials" Liquid @ Target!
Well, Fels Naptha was never considered a "natural/mild" soap. In the absence of modern surfactants and enzymes, alkaline cleaning products were the best one could probably have to clean greasy/oily dirt. Fels went one better by adding naptha, which being a petrol substance helped greatly in dealing with oil and grease. All one had to do was wet and lather up items with Fels, allow them to sit for awhile and the soap would do the work of attacking dirt and oils. I've tried this method and it does work, in fact I'd put vintage Fels up against modern stain treatments for grease and oil based stains any day. Lipstick, some types of ink, dyes, tar, grease, oil, and so forth are easily tackled by my vintage Fels soap.
L.
My father(80yrs old) says his grandmother used to make soap cakes from fat and lye and it was used in the bathroom, kitchen sink, and the laundry which was a copper Easy wringer washer manufactured here in good old Syracuse, in those days. This had to have been around 1935, his earliest recollection. She used to then make "soap chips" for the laundry and dishpan to dissolve better. To the point made above, the fat and alkali of the lye create a chemical effect that loosens soil to go with it. Many people of my father's generation used to call the laundry stuff,even in the 50's &60's, soap chips instead of detergent, due to poverty/depresssion upbringing. I wonder how old the word "detergent"is in the venacular?
Fels Naptha
We always had a cake of Fels Naptha on the laundry tub. My mother would use it on collars and grease stains and would banish us to the basment laundry tubs when we played in the mud or tar as they were building our subdivision, to wash our filthy hands,and sometimes bodies. It was like a comination of wax, sandpaper and turpentine. If you had to resort to the Fels Naptha, you were the filtiest kid in the neighborhood. It was a Mommie Dearest, Carrie's religious Mother memory for me. I am surprised she didn't use it on the dog, who was big, strong and mean, but scared shitless of my 100 lb 5'2" mother. She leveled out later on meds and got a teaching job. She hated running the house by herself, and my father pitched in and gave up his second job. To this day, however, Fels Naptha to me is like a raw steak to Christina Crawford.
Good Soap Discussion
There's a good article on soap - and soap making - on Wikipedia.
Here are some excerpts:
Soap is a surfactant used in conjunction with water for washing and cleaning. It usually comes in a gas moulded form, termed bars due to its historic and most typical shape. The use of thick liquid soap has also become widespread, especially from soap dispensers in public washrooms. Applied to a soiled surface, soapy water effectively holds particles in suspension so the whole of it can be rinsed off with clean water. In the developed world, synthetic detergents have superseded soap as a laundry aid.
Many soaps are mixtures of sodium (soda) or potassium (potash) salts of fatty acids which can be derived from oils or fats by reacting them with an alkali (such as sodium or potassium hydroxide) at 80°–100 °C in a process known as saponification. The fats are hydrolyzed by the base, yielding glycerol and crude soap. Historically, the alkali used was potassium made from the deliberate burning of vegetation such as bracken, or from wood ashes.
Soap is derived from either oils or fats. Sodium tallowate, a common ingredient in many soaps, is in fact derived from rendered beef fat. Soap can also be made of vegetable oils, such as olive oil. Soap made entirely from such oils, or nearly so, is called castile soap. The use of the word "soap" has become such a household name that even cleaning solutions for the body that don't have soap in the ingredients are referred to as soap.
[edit] Purification and finishing
The Common process of purifying soap involves removal of sodium chloride, sodium hydroxide, and glycerol. These impurities are removed by boiling the crude soap curds in water and re-precipitating the soap with salt.
Most of the water is then removed from the soap. This was traditionally done on a chill roll which produced the soap flakes commonly used in the 1940s and 1950s. This process was superseded by spray dryers and then by vacuum dryers.
The dry soap (approximately 6-12% moisture) is then compacted into small pellets. These pellets are now ready for soap finishing. Soap finishing is the process of converting raw soap pellets into salable product, usually bars.
Soap pellets are combined with fragrances and other materials and blended to homogeneity in an amalgamator (mixer). The mass is then discharged from the mixer into a refiner which, by means of an auger, forces the soap through a fine wire screen. From the refiner the soap passes over a roller mill (French milling or hard milling) in a manner similar to calendering paper or plastic or to making chocolate liquor. The soap is then passed through one or more additional refiners to further plasticize the soap mass. Immediately before extrusion it passes through a vacuum chamber to remove any entrapped air. It is then extruded into a long log or blank, cut to convenient lengths, passed through a metal detector and then stamped into shape in refrigerated tools. The pressed bars are packaged in many ways.
Sand or pumice may be added to produce a scouring soap. This process is most common in creating soaps used for human hygiene. The scouring agents serve to remove dead skin cells from the surface being cleaned. This process is called exfoliation. Many newer materials are used for exfoliating soaps which are effective but do not have the sharp edges and pore size distribution of pumice.
[edit] Uses
Although the word soap continues to be used informally in everyday speech and product labels, in practice nearly all kinds of "soap" in use today are actually synthetic detergents, which are less expensive, more effective, and easier to manufacture. While effort has been made to reduce their negative effect upon the environment, the results have been mixed.
Soaps are useful for cleansing because soap molecules attach readily to both nonpolar molecules (such as grease or oil) and polar molecules (such as water). Although grease will normally adhere to skin or clothing, the soap molecules can attach to it as a "handle" and make it easier to rinse away. Allowing soap to sit on any surface (skin, clothes etc) over time can imbalance the moisture content on it and result in the dissolving of fabrics and dryness of skin.
(fatty end) :CH3-(CH2)n - COONa: (water soluble end)
The hydrocarbon ("fatty") portion dissolves dirt and oils, while the ionic end makes it soluble in water. Therefore, it allows water to remove normally-insoluble matter by emulsification.
Soap water can be used as a nature friendly way to get rid of an ant problem in your food. By pouring soap water on an ant trail it destroys the ant's sense of smell and the scent the ants were following to get to the food.
[edit] The history and process of soap making
Main article: Soapmaking
1922 magazine advertisement for Palmolive SoapThe earliest known evidence of soap use are Babylonian clay cylinders dating from 2800 BC containing a soap-like substance. A formula for soap consisting of water, alkali and cassia oil was written on a Babylonian clay tablet around 2200 BC.
The Ebers papyrus (Egypt, 1550 BC) indicates that ancient Egyptians bathed regularly and combined animal and vegetable oils with alkaline salts to create a soap-like substance. Egyptian documents mention that a soap-like substance was used in the preparation of wool for weaving.
It is commonly reported that a soap factory with bars of scented soap was found in the ruins of Pompeii (79 AD). However, this has proved to be a misinterpretation of the survival of some soapy mineral substance,[citation needed] probably soapstone at the Fullonica where it was used for dressing recently cleansed textiles. Unfortunately this error has been repeated widely and can be found in otherwise reputable texts on soap history. The ancient Romans were generally ignorant of soap's detergent properties. The word "soap" appears first in a European language in Pliny the Elder's Historia Naturalis, which discusses the manufacture of soap from tallow and ashes, but the only use he mentions for it is as a pomade for hair; he mentions rather disapprovingly that among the Gauls and Germans men are likelier to use it than women. [1]
The Arabs made the soap from vegetable oil such as olive oil or some aromatic oils such as thyme oil. Sodium Lye (Al-Soda Al-Kawia) NaOH was used for the first time and the formula hasn't changed from the current soap sold in the market. From the beginning of the 7th century soap was produced in Nablus (Palestine), Kufa (Iraq) and Basra (Iraq). Arabian Soap was perfumed and coloured, some of the soaps were liquid and others were hard. They also had special soap for shaving. It was commercially sold for 3 Dirhams (0.3 Dinars) a piece in 981 AD. Al-Razi’s manuscript contains recipes for soap. A recently discovered manuscript from the 13th century details more recipes for soap making; e.g. take some sesame oil, a sprinkle of potash, alkali and some lime, mix them all together and boil. When cooked, they are poured into moulds and left to set, leaving hard soap.
A story encountered in some places claims that soap takes its name from a supposed "Mount Sapo" where ancient Romans sacrificed animals. Rain would send a mix of animal tallow and wood ash down the mountain and into the clay soil on the banks of the Tiber. Eventually, women noticed that it was easier to clean clothes with this "soap". The location of Mount Sapo is unknown, as is the source of the "ancient Roman legend" to which this tale is typically credited.[2] In fact, the Latin word sapo simply means "soap"; it was borrowed from a Celtic or Germanic language, and is cognate with Latin sebum, "tallow", which appears in Pliny the Elder's account. Roman animal sacrifices usually burned only the bones and inedible entrails of the sacrificed animals; edible meat and fat from the sacrifices were taken by the humans rather than the gods. Animal sacrifices in the ancient world would not have included enough fat to make much soap. The legend about Mount Sapo is probably apocryphal.
Historically, soap was made by mixing animal fats with lye. Because of the caustic lye, this was a dangerous procedure (perhaps more dangerous than any present-day home activities) which could result in serious chemical burns or even blindness. Before commercially-produced lye was commonplace, it was produced at home for soap making from the ashes of a wood fire.
Castile soap, made from olive oil, was produced in Europe as early as the 16th century.
In modern times, the use of soap has become universal in industrialized nations due to a better understanding of the role of hygiene in reducing the population size of pathogenic microorganisms. Manufactured bar soaps first became available in the late nineteenth century, and advertising campaigns in Europe and the United States helped to increase popular awareness of the relationship between cleanliness and health. By the 1950s, soap had gained public acceptance as an instrument of personal hygiene.
[edit] Handmade soap
Handmade soapSome individuals continue to make soap in the home. The traditional name "soaper", for a soapmaker, is still used by those who make soap as a hobby. Those who make their own soaps are also known as soapcrafters.
The most popular soapmaking processes today is the cold process method, where fats such as olive oil react with lye. Soapmakers sometimes use the melt and pour process, where a premade soap base is melted and poured in individual molds, but this is not really to be considered soap-making. Some soapers also practice other processes, such as the historical hot process, and make special soaps such as clear soap (aka glycerin soap).
Handmade soap differs from industrial soap in that, usually, an excess of fat is used to consume the alkali (superfatting), and in that the glycerin is not removed. Superfatted soap, soap which contains excess fat, is more skin-friendly than industrial soap; though, if not properly formulated, it can leave users with a "greasy" feel to their skin. Often, emollients such as jojoba oil or shea butter are added 'at trace' (the point at which the saponification process is sufficiently advanced that the soap has begun to thicken), after most of the oils have saponified, so that they remain unreacted in the finished soap.
[edit] Soap Substitutes
These plants are supposed to contain saponins in sufficient quantities to produce lather (when mashed plant parts are beaten in water) and can be used in either soap or shampoos:
The soap plant group (amole root, soap plant root, soaproot bulb), guaiac leaves, papaya leaves, Quillaia bark, Red campion root and leaves, Atriplex root, Sapindus fruit, soap pod fruit, Mohave yucca root, Soapwort root, Our Lord's Candle root, wild gourd fruit.[1]
[edit] Disadvantages
Today, fat-based soaps have mostly been superseded by modern detergents. Washing agents do not contain soap for cleaning fabric, but for reducing foam.
The disadvantages of commercial soaps are:
Due to the fact that most commercial soaps eliminate the glycerine from soaps to use in other industries, this deprives the skin of the natural, moisturising glycerine and generally leaves the skin feeling dry. Due to this, many Bedouin tribes in the Middle East have shunned soap, prefering instead to simply scrub themselves with sand while bathing in simple water.
Soap can react mildly basically with fabrics resulting in damage over the long term. This is usually due to excess sodium hydroxide (NaOH, an alkali/base) left from manufacture, but can also be caused by the very slight presence of NaOH from the equilibrium reaction:
R-COO-Na + H2O ↔ R-COO- + Na+ + H2O ↔ R-COOH + NaOH
However, this equilibrium strongly favors the left-hand side so the fraction of NaOH formed is minuscule
Soap reacts with lime to form an insoluble deposit (soap scum) in "hard water":
2Na+(R-COO)-(aq) + Ca2+(HCO3-)2(aq) → 2Na+(HCO3)-(aq) + Ca(R-COO)2(s) - where R stands for an alkyl group (ppt)
A wide variety of emollient materials, such as shea or cocoa butters, are substantive to the skin.
Poorly finished soaps contain alkali (NaOH) and react mildly basically with skin and fabric; commercial products are finished to neutrality or to a weak acid content to prevent this and be more compatible with the skin's slightly acidic pH.
Commercial products use chelating molecules(sequestrants), often EDTA derivatives to bind with any free Ca or Mg ions and prevent soap scum. These also help reduce fragrance loss, discolouration and rancidity.
Castile soap has a very high alkalinity level, measured at about 9. pH of skin and hair has a slightly acidic pH level known to be about 5 to 6. Due to the high pH level, liquid castile soap is usually not recommended by soapmakers who market this high pH soap for washing hair because it is not pH-balanced and it may cause hair to become dry.
"Alternative" uses for brown soap
Fels Naptha soap is EXCELLENT for washing off the oil from poison ivy if you get it on your skin!
Also, I occasionally seasonal oily skin from the changes of seasons on my face and nasty pimples, and a good scrubdown of my face with Octagon soap is sometimes just the ticket....
I had an elderly neighbor who swore by Octagon soap as a cure for dandruff!
It's amazing how sometimes the best cures are the cheapest and simplest ones.
I need to amend and update my previous evaluation of this product.
I've used less liquid in all sizes and types of washes and it STILL foams up....and I see now that the amount of foaming is way too excessive. It also does not rinse out easily.
Please remember that, I am in a soft-water area.
That said, I'm not sure I can recommend this detergent, because I would think that the failure to rinse clean and leave detergent residue may cancel out the benefits of the gentler ingredients that are used in its manufacture....
Maybe the hardcore collectors could use it for "suds-cake"?
I really wanted to like this one....
quite true, oxy
too much OBA (imo) for darks. IMO towels washed in this stuff need an extra rinse. no good for front loaders, too much suds. quite sad, since i LOVE the fragrance.
Shook it up....Then again i also poured a little in the cap and back into the bottle...
was trying to see if there where any non HE arm and hammer products that didn't make too many bubbles
