New Dehumidifier: Frigidaire FAD704DWD
frigilux
Mar 3, 2007
12,665
The Minnesota Prairie
Every summer I think about buying a dehumidifier for the lower level of my house. The house is built into a hill, so the front (west) of the lower level is above ground, while the back wall (east side) is underground, like a regular basement. The front room was intended to be a family room, but I use it as the living room. The back half contains the laundry room/bathroom and an open area I use for an office. The rest of the lower level is taken up by a heated/air-conditioned tuck-under garage.
Anyway...the humidity level is always a little high down here during the summer, and with my asthma/allergies running at full-tilt this summer, I finally purchased a dehumidifier online from Amazon.
It's a Frigidaire, model FAD704DWD with an Energy Star rating, so I'll get $25 back from my local utility. It's been on for 8 hours and the bucket is nearly 3/4 full. The instructions suggest to run it in the "Continuous" mode for 3-4 days, then select the humidity level you want (35%-85%). The fan will then cycle on/off with the compressor.
Seems to be doing its job; the lower level (where I spend a lot of time since the TV, sofa, office, and laundry are all down here) is noticeably drier already. I have both stairway doors to the main level closed, so it's effectively sealed off.
This was the top-rated model at Consumer Reports, but many user reviews at both Amazon and Frigidaire.com say the same thing: It works great but has a short life. Many complained the compressor gave out in 2-3 years.
User reviews for other brands complained of the same thing, so decided to go with the Frigidaire. Hope it lasts longer than 2 years! The list price is $349, and I got it for $250 at Amazon, with free shipping (via UPS).
(Aside: I used an iPad app called FrameArtist With Photo Templates Pro to get two photos into one post. You can make frames with up to 56 photos in them. There are many other templates to create interesting photo projects. It's free today at Apple's App Store. Easy to use! I've always wanted to be able to get more than one photo into a post.
[this post was last edited: 7/16/2013-23:44]
Depending on your humidity, you may have started a bit late in the season. For me here in MI if I don't start the dehumidifier in April it's a loosing battle. Once the concrete in the basement gets saturated my unit runs 24/7. It's not cheap either, mine costs about $30/mo to operate.
You may be in a better position since you are not completely underground. I've hooked mine up to a drain line, if not I empty it 3times a day. You can also get a small pump that drops into the tank and will pump out the water when needed.
Have a Frigidaire I bought about 3 years ago, and like it fine.
Have a couple Kenmores less than 5 yrs. old, and one of them broke right after the warranty ran out. Then last week I got a postcard from LG that they are recalled due to fire hazard.
Friedrich
I bought a Friedrich D25BNP for use in the cellar. $190 from PC Richard, which seemed to be the only company that had this model. The main reason I purchased this new model is that it runs on only 2.2 amp. I drain it directly into settub, so I don't know the volume of water removed. The drain hose drips constantly, though.
Friedrich website had incorrect information on this model. It was (and may still be) listed as 4.5 amps, 290 watts. I talked to tech support at Friedrich, and the person agreed with me. Or maybe just said he did, to end the phone conversation.
I run it for perhaps 12 hrs./day. Digital readout never seems to go below 49% humidity, although I set it for 30%. I realize that this unit is small for the area of the cellar, but, using that small amount of electricity, I figure that it's better than nothing.
