new electric dryer needed
maylingsmom
Apr 28, 2015
45
My dryer is no longer drying. It gives off a little tiny bit of heat in the drum but the back is getting pretty hot. My husband doesn't want to try to fix it and says I need to look for a new one. I have a Speed Queen washer but am NOT interested in getting the matching dryer. I just need something that dries. Any suggestions for one? We are retired folks so no need for anything fancy.
If the back is getting hot sounds like the vent may be clogged with lint and needs to be cleaned. This could cause a fire if in fact the vent is clogged. Clearly the element is heating if the back is getting hot.
A friend of ours has her dryer in the garage. She had a similar problem. Her husband fixed it by using a leaf blower up the stack through the roof. A few moments after he started it looked like it was snowing outside! There was a LOT of lint in that dryer and vent! It's also a fire hazard too!
We use our chimney sweep to clean ours out. [this post was last edited: 8/11/2015-01:34]
I agree...check your venting!
You definitely need to check to see if the exhaust vent to the dryer is clogged as well as the lint screen itself. If the dryer is heating up and getting hot the way that it should but is not able to exhaust the heat by circulating air thru the dryer you could possibly have yourself a dryer fire. That's the last thing you want to happen.
Slow Dryer
Yes as others suggested you may have a clogged vent, best way to test is to pull the exhaust hose off the dryer and dry a few loads, if the dryer works great you instantly know you have a vent system problem.
A new SQ dryer is a very practical and low cost way to get a very reliable dryer, and if you have natural gas in your home consider switching to a gas dryer, running a NGD does only about 1/3 the damage to the environment that running an electric dryer does.
If you do find that the vent was blocked with lint, there is a great probability that the blower might be clogged also. Have found this to happen also. Might be time for a complete cleanout.
Jon
