toggleswitch2
- Joined
- May 23, 2008
- Messages
- 5,000
1 inch = 2.54cm and yes 2 inches makes a big difference.
A "standard" U.S. door tends to be 30" (figure 75cm) for rooms within a house. [Not the entries, which are larger].
The jamb ("molding") on each side (against which the door closes) takes off 1+1 inch (2 inches total) so that leaves 28" total clearance. I believe this is why a U.S. washer has (had?) a 27 x 27 footprint.
Bathroom doors and linen closet doors tend to be 24" (60cm) wide. TRUE compact/portable washers and/or dryers have one dimension at or near 24" and another that is usually LESS than 24" to get into these spaces/rooms via narrow doorways.
