New find Maytag a50/de50... questions and help needed...
classiccaprice
Jun 26, 2007
2,059
Hampton, Virginia
hi everyone!
I just picked up a 1970 Maytag A50/De50 set in white.
I'm so excited to use them!
Question: what other colors were there? I've seen Harvest, Avocado, and Coppertone. I read that the model was introduced in 64. Were they available in sunny yellow, turquoise and pink?
So I checked them both. The belt for the blower motor on the dryer and the impellers on the washer have both fallen apart with age. Any leads on replacements?
The washer sadly took a dive when moving and both knobs were destroyed. Anyone have extra A50 knobs? Thanks!
So I found a guy on ebay who will make custom belts. Based on my measurements the washer belt is 50 inches and the dryer belt is 34 inches. Will keep you posted!
I called John and left a message about the knobs. If anyone else has any leads in the mean time, please let me know!
Thanks so much.
I ordered the belts. Will keep you posted.
Future reference, John does not have knobs for the A50. If anyone comes across a pair, let me know.
Also, my question was never answered. Did they offer the A50/De50 in turquoise, yellow and pink?
Thanks everyone.
Will, you did a great job gluing those knobs.  You know you might be able to find some generic white knobs with the same style hole that fits the control posts.  Then mark them with a label maker of even a sharpie to match the original knob settings.  Then you could use these, save the originals from possible breakage from use while glued and keep looking for original replacements.
I had one just like this from 77’  to 85’.  It was a great little washer.  Fun to use and did a remarkable job of washing a weeks worth of laundry in about an hour.
I hope you’ll enjoy yours as much as I did mine.
Eddie
Not a bad idea, Eddie. I may do just that.
My belts arrived today. The dryer one works, but it rattles. I should have done 33 or 33.5. What glue should I use if I cut out and make it shorter?
The washer belt fit perfectly and mechanically worked well on her first wash with me, except for the diverter valve... both tubs filled and drained at once! Something else to hunt for.
Thanks everyone!
Will, I don’t know if you can effectively cut and glue this dryer belt to shorten it.  I think the heat from the dryer may cause the glue to fail.  I’m sure that there may be other members that have some suggestions that may work for you.  If you enter Maytag A50 owners manual into your search engine you will find a couple of websites that you can download the owners manual from, and this would be handy to have.  There are also sites that still have some parts available, but no knobs.
If you’re not familiar with using a twin tub, the process is basically like washing with a wringer washer, except you use the spin tub instead of a wringer.  I always sorted my loads into whites, light colors and dark colors, washing and spinning them in succession and holding them in a laundry basket.  Once the washing was done, I’d drain the wash water, and fill the wash side with rinse water and then rinse and spin out each load in the same order they were washed in, adding additional water and detergent as necessary.
At the time I owned mine I only had a double bed and I could wash the blankets and bedspread in the A50, just one at a time with no problem.  Any larger sized bedding may be a stretch, certainly not king sized, but you may be able to wash a light weight queen sized blanket.
 I usually did the towels in a separate load.  At the time I was still working as a hairdresser and I used to do some hair at home, so at times I’d have lots of towels.  BTW, I always filled the wash side with full on hot water, so for the first load or two I sometimes used a large wooden spoon to fish out the items into the spinner to avoid burning my hands.
And I left the impellers running so the clothes would rise to the surface and be easier to capture and get out.  As long as you keep your hands away from the back of the tub you won’t get hurt, and anyway those impellers don’t have any sharp edges to really inflict any harm.
Have fun with this bad boy!
Eddie
I just wound up ordering a new one at 33 inches for the dryer.
If I order them again, and future reference for any post readers, I'd take an inch off each belt. The washer belt should have been 49 inches and the dryer belt is 33 inches... I'd consider 48.5 and 32.5 as well. They work at the larger lengths, but they aren't but so tight and the dryer rattles. It still rattles slightly at 33 inches, but it's something I can live with.
Now I just need to find a suds saver diaphragm for the bottom of the tub and of course those knobs...
fun. fun. fun.
Part #????
John I have located one but would you know the part #?? Is it shaped like a miniature football goal post??? They list it as part # 202504 I have not had mine apart in years . This part looks like hard plastic. Is the diverter valve suppose to be rubber??? Thanks
Hey all,
Just had to replace the washer belt due to user error. I shortened both up by 2 inches. 32" for the dryer (thanks John) and 48" for the washer. They both fit much better. I just wanted to update for archival reasons.
