New Find!
Automatic Griddle
Wouldn't be nice to have opened the left storage drawer and the automatic griddle was sitting there pretty as can be?
Wow!
That's my all time favorite stove and my all time favorite appliance color. One of my aunts had one in white.
Have fun with it and thanks for sharing!
Mike
Griddle
Had this stove growing up(in white).......Hotpoint....with the griddle. It was a HEAVY griddle that plugged in to the back. Used the griddle all the time for bacon or grilled cheese sandwiches. Also, the left burner dropped down so it would make a well.....kind of nice for deep frying.
The pushbuttons lit up different colors. There was a large oven and a small oven.
It was great for its time.
Gary
Griddle confusion!
Suddenly it all becomes clear...
I was wondering why the griddle would connect over the two left burners rather than over at the right on the "blank" part. I have a '54 Hotpoint commercial showing their griddle which plugs in at the right, and made the Hotpoint-->GE leap.
This morning, I read the page in the manual (I have a bigger monitor at work than at home...). Looks like the "plug" for the griddle is thermostatic only and the heat comes from the actual burners. This is unlike the Hotpoint which has its own heating element and thermostatic control ("This looks like the answer to Jim's Sunday morning breakfast of pancakes!")
Now I can sleep well.
Automatic griddle
I think I get it, it uses the Sensi-Temp of the front unit to control BOTH units when the griddle is plugged in
GE Automatic Griddle
OK, so here's how it works:
Thomas E Stiyer <[email protected]> wrote:
> Hey Guys,
> Since I have two of these in white, I will be glad to answer your
> questions. The outlet labeled Automatic Grill has a very interesting
> function. You see the small left front surface unit with the sensor?
> Note that in the bank of pushbuttons, there is one lens with no
> buttons that is labeled Automatic? OK, the dial on the left of the
> meat thermometer gauge is the control for the automatic unit. It is
> not labeled in degrees, but in settings explained in the owner's
> manual, like for frozen vegetables set to *. When you plug the big
> aluminum griddle into the outlet it links the large rear surface unit
> and small automatic one so that both are thermostatically controlled,
> but it does something else to make the heat even. The 8 inch
> elements are configured like the 6 inch element in front with an
> inner section and an outer section. When you plug in the griddle,
> only the outer section of each element heats. The griddle has two
> raised rings on the underside that sit on these parts of the two
> surface units so that theoretically the heat will travel to the outer
> edge of the griddle in about the time it takes to travel inward to
> signal the sensor that the selected setting has been reached. As for
> the knob to the right of the meat thermometer, it is the switch for
> the fluorescent surface light just above it under the chrome and it
> lights the GE emblem and the words.
> Now, the neatest part of the range, and this was the last year they
> were used, is the clear pushbuttons and the Tele-Cook lights. Each
> heat had a color and when you pushed a button, a C-7 bulb in the
> button assembly in the control panel lighted and light coming through
> a color lens behind the button made the lighted color. The Automatic
> unit just lights up clear. There are also lights for both the oven
> set dials (Bake, Time Bake, Broil in the Companion Oven and those
> three plus Rotisserie in the Master Oven) that are lighted as long as
> the oven is on and a light over each of the oven thermostat dials
> that cycles with the oven elements.
> I have a double wall oven with woodtone brown doors with a window in
> the top oven and a solid door in the lower oven. These ovens are
> both the same size as the master oven in the range, a huge 23 inches
> and I can place two Bundt pans on the rack in both upper and lower
> ovens.
My eyes are a poppin'!
Gosh Bethann!! How the heck did you ever find such a terrific range!! It is absolutely gorgeous and immaculate!! Thank heavens someone didn't trash it. Now it is in the right and appreciative hands!! Congrats! :-)
Venus
Bethann I love your new range!! Now both you and Venus will have something beautiful to cook on. Thanks so much for sharing with us. Terry
